10 Second Club Now you are haulin! 10s are sweet
10.99 @ 122
Old 04-15-2010, 09:28 PM
TA1364's Avatar
Default 10.99 @ 122
Went one 10.99 @ 122.85 before getting kicked out. Car is ms3/125 shot, it needs to be on a dyno pretty bad tho. Only weight out of it is exhaust ends after the Y, spare tire and 15" wheels. Stock tranny, stock rearend.
1.56
7.00@98
10.99@122
Old 04-16-2010, 10:38 AM
MASS seller approved
smok'nZ's Avatar
great time for a budget set up
Old 04-16-2010, 12:28 PM
TA1364's Avatar
Thanks. Theres more in it for sure. Shift points and keeping it out of OD right before the traps should help out.
Old 04-16-2010, 12:46 PM
MATTREDSS's Avatar
Nice time....Congrats!
Old 05-07-2010, 01:30 AM
stoverz28's Avatar
Is it an A4?
Old 05-07-2010, 11:38 AM
TA1364's Avatar
Yes A4. Havent sprayed it since, got it on the dyno yesterday and it put down numbers lower than it did with bolt ons. Got to see whats up.
Old 05-07-2010, 05:44 PM
TheBlueKnight's Avatar
Very nice! What stall and rear tires?
Old 05-07-2010, 11:39 PM
TA1364's Avatar
Pt4400, ET streets
Old 05-08-2010, 08:51 AM
MATTREDSS's Avatar
^^^ WTF.......spam
Old 05-08-2010, 01:41 PM
soul strife's Avatar
Did you run it at Kil-Kare? Nice times.
Old 05-08-2010, 01:50 PM
BAD-LSX-7's Avatar
put a 150 in it off the line with a slick and do work!
Old 05-08-2010, 06:45 PM
TA1364's Avatar
Yes at kilkare. I want to get the power I have sorted out first. It went 120mph on the same size shot before the cam swap.
Old 05-10-2010, 12:14 PM
99corvette's Avatar
Yeah its called breakage of the 10 bolt lol
Old 05-10-2010, 05:07 PM
TA1364's Avatar
I want to spray off the line but with stock suspension and a not so great track it doesnt hook to well. Maybe if I get slicks it will hook.
Old 05-11-2010, 12:48 AM
180ls1's Avatar
might be trans slip.
Old 05-21-2010, 06:23 PM
Mike Comp T/A #57's Avatar
Congrats!
I like Kil-Kare
Old 05-26-2010, 12:21 AM
blwn_00gt's Avatar
Pt4400, ET streets
congrats on the time.
i thought that stall would be to loose for spray but i see its working quite well for you...
Old 05-26-2010, 01:55 PM
TA1364's Avatar
It blows through a little bit I think. I am shifting at 6000 and I have to have a 6400 pill in the window switch for the nitrous to stay on.
Old 05-26-2010, 04:10 PM
BAMALS1's Avatar
Good times for the mods! That's crazy fast on a 10 bolt lol.
Old 06-03-2010, 02:15 PM
blockheadnic's Avatar
Good times Sam.
I need to get off my *** and finish my cam install.
Quick Reply: 10.99 @ 122
