10.28 @ 133 in a 6spd
Figured I post up my results from last nights outing. Only got 3 pass but I was happy with all three. 1st past I started off with a 10.419 @ 132.80, 1.50 60ft. 2nd pass was a 10.411 @ 132.92, 1.44 60ft. I short shifted the 2-3 & 3-4 shifts. The final pass was a 10.286 @ 133.46, 1.42 60ft.
My set is as follows: LS1 347, 11.2:1 compression, PRC stage 2.5 5.3L heads, custom 23x cam, ported FAST 92, HSW 92mm SI plate jetted for a 150 shot, Tick level 2 T56, Mcleod RXT twin, Tick master cyl, PST 3.5in aluminum drive shaft, and a Moser 9 inch with 3.89's and a locker. For suspenion, QA1 SA rear shocks, Spohn rear drag sway bar, BMR LCA, and a BMR torque arm w/ relocation bracket. Front suspenion is all stock minus the front sway bar. Right now the car is still full weight with all the functioning factory options (ABS/TCS, AC, 12 disc cd changer, pwr windows and door locks, etc) The car weights about 3700lbs with my fast *** in it haha
Hoping to up the shot an remove more weight and crack 9's with a 6spd
Heres the Slip
Video of the 10.28 pass
Heres the Slip
Awesome good times with a 6spd...get some weight out of that thing. Looks like you went to Atco,take it to Cecil on a Saturday test and tune. You will get a bunch of pass's. I got 7 runs 2 weeks ago and could have got more.
Way to go Rob your driving has really made this well put together set up shine.
May be we should hit the rollers to see what it puts down but with results like this its almost pointless the Track numbers don't lie.
All that track testing and Tuning we did is paying off who know may be by the end of the year we'll squeeze out some single digits with a car in full street form looks and sounds mostly stock. SLEEPER!!!
I want to try to get my 99 chicken in the 10,s with a hand shaker so watching what you guys results are. Want to do it without spray but do not know if it is doable with stock inch motor.
