10 Second Club Now you are haulin! 10s are sweet
10.99@125.5 on a 1.49 with a Monster Level 2 and 422rwhp!
Old 11-05-2011, 11:39 PM
SNLPerformance's Avatar
Default 10.99@125.5 on a 1.49 with a Monster Level 2 and 422rwhp!
The DA was about the same as last friday(-400) the track was hooking well and I was ~50 lbs heavy with a 1/2 tank. Still not sure how a .14 improvement in the 60' only equates to a .03 overall I'm more amazed at the 1.4 honestly, the splits were off .03 from the 60-330, .04 from the 330-660 and .06 from the 660-1320. So I think it's safe to say there's a 10.8x in it and a 6.9x in the 1/8, but I called it a night not wanting to push my luck with breakage and can officially say it's a 10 sec sleeper! The 11.01 was the shakedown pass, guess I had to get that last 11.0x out of the way There will be video soon for any that question the number error on the slip and as Fartpipe says, it didn't happen without it!
http://www.youtube.com/watch?v=wNb3m...layer_embedded
Old 11-06-2011, 11:48 AM
6.0monsta's Avatar
Doesn't count. You let a Honda drag you down the track.
Old 11-06-2011, 12:37 PM
BayAreaSS's Avatar
Congrats man good pass!Thats an impressive car for sure. That time slip looks very similar to mine and i make roughly the same power except I have an fbody. Whats your setup?
Old 11-07-2011, 12:01 PM
Haha, it was good motivation...technically I won as he redlighted must say it's one of the best launching/setup fwd cars I've seen at the track
Old 11-07-2011, 12:03 PM
Thanks, it's a 99 FRC with my 218* sleeper cam, PRC stage 2.5 5.3L heads, Ported Fast 92 and 4.10 gears basically.
Old 11-07-2011, 12:11 PM
BayAreaSS's Avatar
That's real good for a small cam. I have the same setup except I have a medium size cam and a fast 90. Whats your race weight?
Old 11-07-2011, 12:14 PM
Thanks, it makes good average power...~3150
Old 11-07-2011, 12:34 PM
HioSSilver's Avatar
Good run. What rpm and tire height do you have goin on? I could only trap 122 with 4.10@6800 on a 25.7" tire.
Old 11-07-2011, 04:21 PM
~6600, I run the Bias Ply 26" ET Streets they grow a little on the big end
Old 11-07-2011, 05:49 PM
HioSSilver's Avatar
They must grow more than a little for you to trap more with the same gear and less rpm. I ended up changing to 3.90's to get threw the traps.
Old 11-07-2011, 10:05 PM
navyblueSS's Avatar
Nice!
Old 11-08-2011, 12:10 AM
BayAreaSS's Avatar
Oh ok your car is lighter then mine for sure.
That doesn't make sense. My car has 4.10s and 25.2" tall hoosier drag radials. and I trap over 123. I hit the limiter at 125mph at 6800rpm
Quick Reply: 10.99@125.5 on a 1.49 with a Monster Level 2 and 422rwhp!
