Go Back   LS1TECH > RACING DEPARTMENT > 10 Second Club
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
10 Second Club Now you are haulin! 10s are sweet
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 04-16-2012, 06:06 PM   #1
Garage is empty, add now
Trader Rating: 1
Default in the 10's 1991 camaro
Engine 2004 lq4 .030 with forged flattop pistons. Ls2 rods. Stock crank 821 (ls3 heads). Ported valve job and milled. 035". Flowed around 360 cfm at. .700 lift eps custom grind 235*/251*@050" 621/632 lift 110+4 installed straight up Jp roller timing set. .040 head gasket Prc. .650 spring kit titanium retainers 7.325"pushrods Ls7 lifters with. 080" preload 1 3/4 primary 3 collector longtube headers. 3"duals. Port matched l92 victor jr 1"spacer 850 proform carb. 76 jet primary with 6.5 pv. 84 jet secondary msd 6010 set at 30* timing straight across. Tr55's gapped. 040" Holley black fuel pump set at 8psi
Specs 1991 Camaro -Full suspension with drag springs and shocks -th400 w/ brake. 8"converter 4500 stall. - Moser 9" 4.11:1 locker - 28 x10.5s x15 et drags with skinnies up front
1.531 60'
6.991 @98mph
10.97@ 124mph
jgillen91 is offline   Reply With Quote
Old 07-18-2012, 03:41 PM   #2
1991 Chevrolet Camaro
Bradlyj8Z28's Avatar
Trader Rating: 4
Cool. Any pics leaving the tree?
Bradlyj8Z28 is offline   Reply With Quote
Old 08-10-2012, 10:35 AM   #3
Trader Rating: 1
Update 10.72 @126.25
1.49 60'
Build thread. http://www.thirdgen.org/techboard/or...-lq4-91rs.html
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
10, 1991, 91, camaro, canada, heads, job, ls1, ls3, racing, specs, stock, timing, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
