You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
the car made 415rwhp/418rwtq on motor and my spray tune should be in the next coming week so we'll see what she makes on the 150 shot. (hopefully over 550rwhp/600rwtq but well see)
i would be launching on slicks and skinnies with a dana60 rear (4.10s/detroit locker) and front sway bar removed.
suspension mods:
Kenny Brown Double Diamond Subframe Connectors
BMR Strut Tower Brace
UMI Adjustable Pan Hard Bar
Eibach LT1 Pro-Kit Lowering Springs
Koni Sport Adjustable Shocks (Koni Yellows - 4/3 Package)
BMR Poly/Poly Adjustable Lower Control Arms (Rear)
first off, im curious if i can expect to pull the front wheels if i can get the launch rpm correct?
second, should i expect to at least make it into the 10s?
thanks guys!
Mike
with the cam alone launching you might get a little bit of air but with the 150 added to it and depending on how your suspension is setup you will be able to lift them and deff make it into the 10's. You should be well into the 10's to
__________________ 1998 z28 camaro A4
slp headers and catted y pipe, borla catback, ls6 intake underdrive pulley, Yanks SS3600, 3.73's and dyno tune
1981 malibu sold
new toy 86 regal
No reason a well-driven 6-speed Fbody with 4.10s, slicks and skinnies, and around 550/600 to the wheels can't go high 10's anyways at full weight or close to it (DA pending, of course - it might not do it up in Denver, for example). I didn't notice you mention the weight (with driver).
Then again, you've gotta drive it to a 10-second pass. With the variables above, it can certainly do it, but it's not gonna be a given with mediocre driving and weather. If you end up with 520-530ish and your driving/launch isn't that great, or you're running in a higher DA, you might be stuck in the low/mid 11's until you get some practice in.
For reference, I went 11.4 @ 121 all day long at a great track in great weather in my full weight 02 Z28 with only 408/380 to the wheels. But at a crappier track in hot/humid weather, it only went 11.7 @ 117. I think I could have pulled off an 11.6 @ 118 at the slower track if I had a little more seat time in that weather. An extra 130-140 rwhp and 200 rwtq should have easily put me in the high 10's traction pending at either track.
I launched that car pretty damn hard, though, but I was also running stock 17" SS wheels up front and 16" bias plies in the back. Real slicks/skinnies would have helped even more.
__________________ 2007 GSXR 600 - Bone stock
its going to depend on how well your suspension is setup and the lightweight flywheel is gonna make the launch tricky your gonna have to ride the clutch a little
