New Best 10.92@127 on 8psi!
5.3L iron block, LS9 camshaft, ls1 intake, comp 918 valve springs, MP t76 1.0ar T4 44mm wg. 4" core IC. 60lb inj, stage 2 snow meth kit with washer fluid, th400 2500 stall converter 8.8 rear qa1 vertical coil overs. microsquirt v3 engine management all in a 2003 Focus ZX3!!!
THIS JUST IN... 1.71 60FT 10.92@127 IN THE 1/4 ON 8LBS, 91OCT AND 13* OF TIMING. 3300lb race weight/w driver.
