10's for my bolt-on ls6!!
#121
Answer my ******* question you dumb ************. Did you not extend your shift points with the tune?
The guys with boss intakes are running them to 7500 or so. Your gonna swing the cams to get it up there. Jesus christ you're a idiot.
maybe hammer will chime in on this. I think he has a before and after vid on the tune in his brothers 5bro.
a tune can make it rev higher than stock. an intake and tune can move your usable RPM on a 5.0 up almost 1500 rpm.
before and after intake and tune. simple pimple. it would rev even higher yet if we wanted it to.
#123
yeah here's another thread where guys are playing with their cam timing.
http://www.svtperformance.com/forums...ble-cam-Timing
i really think he doesn't understand much about engines. he tries to do the talk but it's vague, generic and mostly wrong.
#124
There is the source of Hios misinformation himself.
Here is another one for you, this one is from JPC.. home of the fastest street driven Coyote on the planet. Home of the 9 second sealed stock Coyote. They probably don't mess with cam timing either.
Here: http://www.nmradigital.com/2013/12/1...e-5-0l-engine/
Take note of where that motor peaks power. TiVCT cannot overcome physical restriction, you ******* retard.
Maybe next time Hio says something stupid like this:
You won't open your mouth to look just as stupid. Or maybe it's the other way around, where Hio will think twice about repeating misinformation you fed him.
#126
Now that the "cam timing extends power 20 billion RPMs, derp!" theory is proven wrong.. How about you guys apologize to LS1tech for dumbing everyone down with your misinformed posting.
#129
Yea....cool story. We can get it done on pump and you can't.
We're not stuck at high 10's n/a either.
The cam timing change increases the rpm significantly. I don't know the exact # because I don't own one.
So did your shift points remain stock.
i know wtf swinging the cams can do. Yes it can broaden or shorten the hp curve. Typically depending on where the cams are positioned it moves the power around if the timing of them is changed one way or another. With vvt they are in constant movement and can most certainly extend the power vs stock. Or you would leave your rev limit/shift points in the stock setting.
I think they are a bolt-on. They are however a bolt-on unique to a pushrod engine. They have been considered a bolt-on fir lt's and for old 5.0's. I can see where some want to bitch about them. But lets face it. ....it's not like changing the cam or cam timing.
How embarrassing.
#130
You are too ******* predictable dude. You forgot the "Spaz" and "Redfire" comments too. Typical Hio with nothing to retort.
Oh poor Hummer, to dense to see sarcasm. I know you live on a farm, but didn't realize you were inbred too.
#131
Here is a dyno comparison on my 2011 between a stock intake and a Boss intake using the same cam timing on both. It is clear the stock intake is petering out just after 6500 with the Boss continues to make power.
#132
We've done our own testing with vvt and locking the cams on some s52 bmw's. yes you can move the power around with cam time. Saying you can't is absurd.
So what exact fuel were you on wbt??....oh wait. here's a post from you on svt. Deceive much....lol
wbt wbt is offline
Join Date
December 2010
Texas
Posts
715
I converted to e85 last week.
I want to be clear about this....
It DOES NOT require any fuel system modifications for a 2011+ N/A 5.0. Saying it does is a load of crap. The stock fuel pump and injectors have no issue keeping up with the extra fuel demand.
The only thing needing a change is the tune.
Talk about losing credibility.....and being banned on top of that.
Correct me if I'm wrong....but 10.59 is still the high side of the 10's
Look...I think the 5bro is a good engine. It's no ls but at least it responds to mods unlike the previous furd junk.
wbt wbt is offline
Join Date
December 2010
Texas
Posts
715
#133
Lol You proved nothing wrong you dumb ****. All you proved is that you have no flipping clue whether a tune on a 5.0 can adjust cam timing, and you also proved that you also have absolutely zero clue what adjusting the cams independently actually does. This just furthers everyone's theory that you don't even have a car.
The only people demanding proof from me is you and daddy. I think it is funny watching you guys scramble every time I point out the stupidity in your posts. It's always the same response from you guys in the end.
These guys can't cope with the truth They falsely believe that somehow moving the cams can magically increase usable RPMs. They are to dumb to realize, the cam timing and intake manifold was used to make the motor most efficient in the RPMs Ford wanted it at. They are to stubborn to accept the high RPM potential was already there to begin with.
#134
I don't understand how you can say changing cam timing is an internal mod but changing rocker arms, which could provide more valve lift, is a bolt on.
#135
wbt wbt is offline
Join Date
December 2010
Texas
Posts
715
wbt wbt is offline
Join Date
December 2010
Texas
Posts
715
Even when the facts are presented you brush it aside in favor of your own ignorance. You can't fix stupid.
You don't know the difference between low, mid or high. Stupid much?
BTW - I asked to be banned there. That forum is all about vendor protection and I do not subscribe to that bullshit.
#136
Last I checked e85 is pump gas purchased as the same location a person buys unleaded and diesel. Are you going to say diesel isn't pump gas as well?
#137
That's right....diesel is not pump gas. It is diesel. If you don't believe me try to run it in your 5bro. Your 5bro did not come e85 capable....it is a mod
Are you saying your cam timing is stock?
There you go with that logic mac.
#138
It's a set of rockers dude.....it's not like the wheel was reinvented. Like I said th lt guys used them as bolt-ons and so did the fox 5.0's.
So you're so much of a drama queen you asked to be banned?? LOL....ok.
Lol
#139
1. You change the AFR stoich in the tune.
2. Bolt on cars (no not internal engine mods) will require 47lbs. injectors so you modify the tune for the injectors.
That is it.
Cam timing has nothing to do with it.
Cam timing isn't going to change the powerband of an engine if the intake manifold doesn't allow for it.
Don't get mad at us because we can change cam timing with a tune which requires no internal engine modifications.
Don't get mad at us because we can run 10's N/A, with all accessories, with NO INTERNAL ENGINE MODIFICATIONS.
Don't get mad when you get called on the carpet with your fantasy land reasoning with whom your own peers call you out on.
Don't get mad when you make **** up, get called out for it and look like a fool.
....the list could go on and on and on and......
#140
You can't do that here. You get e85, unleaded and diesel. Seeing as there are many factory equipped cars certified to run e85 there is no reason it should be considered anything but pump gas. Anything else is just ignorant.
Let me educate you on running e85 in a 5.0 2011-2014 Mustang.
That is it.
Edit: i could careless either way tbh but thing is your logic was wrong so i was just showing you why it was wrong
You also need to take weight out, built trans, gears and slicks to run 10s so dont act like its simple bc if it was then everyone would be doing it. Last i checked only a handful of people are running 10s with a bolt on 5.0
