New PB and 2nd request for title change
I have almost exactly the same mods as you (except 3.42 gears) and know there is more in it. (420 rwhp motor unlocked). So.....
What do your 60's look like and what is your race weight?? I am full weight except for sway bar delete.
It's an SS3600 and I have talked to Yank extensively thinking it's to tight (maybe just hasn't loosened up yet). I am currently having window switch coming in at 3100-6600 and it still isn't hitting til about 10'-20' out so it is definitely not flashing to 3600. I've tried leaving from idle, 1000, 2000, but seem to get best 60' at 2500. I have checked the shift extensions (falls 1000rpm on shifts) and even sent a video to Yank. They said they like to see minimum of 800-1000 or they won't restall. They suggested a PA3800. I can't hit out of the hole just yet anyway as I am still on the 10 bolt
My car also does best when I get up against the ceonverter as hard as possible. I leave the hole on about 100, then bring in another 100.
With the 129 trap (same as you), it's making power. I just need to get this pig out of the hole faster! If I can get a 1.4x 60' it should be in the high 10.3x (either that or 10 bolt)
Thanks, good to know. 2500 is all my brakes will hold. I still don't know what she weighs...I'm guessing 3600+
I can leave with my foot on the floor with more consistent launches.
How are you activating the nitrous?
I'm working on suspension lately. Went to a BMR antiroll bar was able to equal my best 60 on half the nitrous. Unfortunately, my last pass of the year I spun, my fault. Believe I'm going after front shocks and different relocation brackets with more adjustment. My car is slammed.
LS1Tech Premium Sponsor
That's my plan, which cam do you have and what is you nitrous setup? Suspension?
OP, it looks like the car is starting to really come around!
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
See this is why I'm scared to change the suspension too much. Right now I'm pretty sure I can get 1.42-1.43 pretty easy and I daily drive the car as well. I just have comp eng 3 ways on the back with stock springs cut. The front is stock struts with intrax lowering springs. It just seems to work, front wheels don't lift either though. I have the pinion set at -.5 degrees, and lca is angled down toward the rear but only .8 degrees. My plan was TRZ relocation brackets and strange sa with 300 springs. Would like to set the pinion back to -2 and get the lca to 2 degrees down as well. If my measurements are correct I have no instant center.
I'm using 3rd gen V6 springs (cut to achieve ride height) for rear and Strange sa w/300 springs front one click from full loose. It definitely leaves better now than with the DMS lowering springs and DeCarbons (sold that set-up for enough to buy the Strange sa's new(f) and the used QA1's (r).
