10 Second Club Now you are haulin! 10s are sweet
5200 lb 04 SSR goes 10's on pump gas and meth spray
Old 10-21-2015, 04:03 PM
Double-L's Avatar
Default 5200 lb 04 SSR goes 10's on pump gas and meth spray
I tried to get the 10 sec but for some reason maybe they don't like yellow or a big truck, A LS6 with JE 8 to 1 blower pistons, Darts heads, Shaft rockers, Eagle stroker crank, Come out to a 377, 122 super charger, 10 pounds of boost, Other good parts, 93 gas with razor Meth spray Moser rear end, M&H 390 Drag radials, Getting ready to put the 5.3 back in and wonder what his engine will do and a roller with a 76 turbo
Old 10-24-2015, 05:22 PM
BIGsmokey10's Avatar
Congrats on your new best. Time for some more boost!
Old 10-24-2015, 05:24 PM
HCI2000SS's Avatar
That's moving at that weight! Nice job
Old 11-08-2015, 09:26 AM
Double-L's Avatar
If you notice the date and still disregarded by the mighty 10 sec. club, I give up on that, Crazy they are some good racers on here, Can't say the same about the ones that runs the forum
Old 11-08-2015, 09:32 AM
Double-L's Avatar
No I tried going from 10 to 15 pounds and I did run faster but the et was slower, Hooking up and the heat, I think at 10 pounds that little 122 maggie is pumping all the air it can
Old 11-25-2015, 11:56 PM
1970camaroRS's Avatar
Damn. With 99% of those trucks being driven in bone stock form by goofs that think they will be worth a million bucks some day, that's actually kind of a sleeper! Looks and sounds like there's more ET in it too with the tire shake/wheel hop off the line.
Old 12-03-2015, 06:56 PM
NewOrleansLT1's Avatar
I believe that you have to add it yourself. Go to your User cp and it should be an option to add it..
Old 12-20-2015, 11:04 PM
Dirty Vegas's Avatar
Lol, I've never seen someone so worked up about a title on a message forum. I think you need anger management more than the title.
Old 01-21-2016, 09:57 AM
Double-L's Avatar
LOL Funny haven't been on in sometime so first time I saw this
Quick Reply: 5200 lb 04 SSR goes 10's on pump gas and meth spray
