Personal goal of tens - Doable?
Hello all, taking another crack at tens n/a after getting close before with a 6 speed.
The new car consists of
85 iroc
Fresh ls1 with loose bearing clearances and arp bolts
Ported and milled ls6 heads
Custom grind fti cam, unsure of specs yet, based off the hellion grind
96mm professional products intake and 96mm tb
4" cold air speed density tune
1 3/4 long tubes with 3" y into 4" single dumped at axle
Pt4000 stall
Built to snot 4l60e running hyguard JD fluid low viscosity
Stock ten bolt with 3:42 gears 4 wheel disk
Lcarb and tunnel mounted short tq arm
Front v6 springs
Battery in rear, a/c delete, bumper brace delete, sway bar delete, etc
17x7 front dark stars and 17x10.5 rear dark stars with 315 nitto 555r tires.
Goal is to dip into tens if I can, will be very tough, but Im going to try. Any pointers or advice? Besides throw my intake away..... Lol
85 iroc
Pt4000 stall
Front v6 springs
It's a fairly light car I'm sure. If your cam is decent and it sixtys really well, I could see it hitting high tens in great air. Run it and report back! There's a few hp to gain with better headers for sure
Any idea on the weight on the car? Dipping into the 10s is definitely possible if the converter and camshaft combination is matched up well. Stepping up to a 3.73-4.10 gear would help as well assuming traction isn't an issue. Factory 10 bolt might not like it too much though.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
I'm not worried about the cam at all, Ed has done about ten cams for me and they all run phenominal. He said he's got something special for me, so I'm excited to try this out. I can weigh the car tonignt, it will be a month or so before I make it to the track, if I had to guess I'd say it's in the area of 3300# race weight. I have high hopes for the converter, but I'm very shocked at how docile it is. It's nothing like I expected, and quite frankly I'm kicking myself for not going 4400. That can always be done if we don't make it this year though. Stepping up gear is an option, but I think I'll go to an 8.8 if I need to get into the rear.
I don't blame you for holding off on the gear swap. In my opinion investing money into the factory 10 bolt is one of the worse things you can do if you are going to actually race with it. I did manage 1.4x sixties on a stock 10 bolt years ago, but it didn't last long with that kind of abuse. It'll be interesting to see your results, I think it might end up taking a little more converter to get you into the 10s though. Keep us posted on the results.
__________________
Thanks! I agree, I'm expecting to run 11.3 or so, and really have to fight to get that last little bit. I'm excited to try it out. I'm fighting a serious miss right now that is only present under a load. Changed coil packs, ND just picked up new tr55's, it has used autolites in it right now haha. Hoping th a t fixes it.
We Swapped my dad's nova and it went 11.9 right out of the gate, on nittos with stock suspension, ls1 with ls1 intake, small cam and a stall in 4800 d/a. We will be stepping his up as well soon.
The best d/a I've ever ran in there was 2,500.
I recieved the cam specs Ed is doing for me, and it's huge. Makes the trex look like a 228r. Seems way to big, but Ed knows what he's doing so I'm excited to try it out.
I would agree, pending the track. Our track is completely surrounded by cornfields, it's very hot and humid year around. D/a was 4800 last time.
