10 Second Club Now you are haulin! 10s are sweet
10s 6speed UPDATE SBE Cam only ls6 n2o
Old 01-15-2017, 03:34 PM
VincesSS's Avatar
Default 10s 6speed UPDATE SBE Cam only ls6 n2o
Got the car in the 10s a few weeks ago.
2002 Camaro SS full weight.
Engine:
Stock 243 heads
Btr stage 4 cam
Fast 78 intake
Stock bottom end
150 nx proton
Sai Li tuned
Transmission:
Stage 2 t56
Stage 2 diamond clutch
Tick master
Pro 5.0 shifter
Rear end:
S60 strac and 4.10s
Running 295/55/15 mt ss radials.
Recently jetted up to 200 and switched to hoosier 28x10.5x15 stiff walls.
I'm in the right.
Gonna drop some weight off the car and hopefully squeeze into the 9s.
Got to the track. Lithium battery, deleted tcs, removed catback.
Old 03-05-2017, 02:15 PM
64post's Avatar
How are you getting drag radials to stick that thing? What RPM are you launching that car?
Old 03-05-2017, 07:25 PM
Jtm2085's Avatar
Awesome times man and the car looks great.
Old 03-09-2017, 09:48 AM
KyleLanter's Avatar
Would like to know how you are getting drag radials to work also. Great times man
Old 03-18-2017, 07:00 PM
VincesSS's Avatar
Very light preload on the clutch and a quick release. About 5-5500rpm.
I switched to slicks for the 10.0 pass.. Makes it a lot easier.
VincesSS's Avatar
Thank you.
Old 03-18-2017, 07:02 PM
VincesSS's Avatar
You just can't side step it. It needs slight preload on the clutch before a quick release. With the slicks you just rev it to the moon and let them bald eagles fly.
Old 03-23-2017, 09:13 AM
StrokN EL Diablo's Avatar
Awesome seeing a full weight car sbe getting it done rowing gears! How do you like that clutch?
Old 03-23-2017, 09:19 AM
Tuskyz28's Avatar
Badass!! What shocks/torque arm are you running ?
Old 03-28-2017, 10:04 AM
Super Hulk Smash
JakeFusion's Avatar
Very nice.
Old 03-30-2017, 09:28 AM
VincesSS's Avatar
Thanks.
Love it. It has been in the car for 5 years. Only about 15k miles on it though, but a lot of passes.
Old 03-30-2017, 09:29 AM
VincesSS's Avatar
Running stock replacement shocks f/r with stock springs in rear with eibach pro kits up front. Bmr chassis mounted torque arm.
Old 03-31-2017, 08:52 AM
VincesSS's Avatar
Here's the full picture of the squirrelly pass I made.
Also I forgot to mention the car runs on e85.
If you like the picture check out killshot, Inc. on facebook, lots of great pictures there.
Attached Thumbnails 10s 6speed UPDATE SBE Cam only ls6 n2o-received_10210562700335228.jpeg
Old 04-01-2017, 05:17 AM
Tuskyz28's Avatar
That pic is sooooo epic!! Just badass
Since you run E85.... how much compression is you running ?
Old 04-02-2017, 06:56 AM
VincesSS's Avatar
Right?! I can't believe that's my car, lol.
Sbe with 243 heads so whatever that is.
Quick Reply: 10s 6speed UPDATE SBE Cam only ls6 n2o
