11 Second Club Snake eyes are a good thing
11s on spray.
Old 04-23-2009, 10:31 PM
blockheadnic's Avatar
Default 11s on spray.
Tonight i ran a new best. on a 125 shot i went 11.15 @ 121 on a 1.60 60' first time on spray this year. untuned with just raised rev limiter and timing pulled
Car is a bolt on stock internal 98 ls1, lost a lot of weight in the car should be around 3000-3100 without me in it.
Has a home built th400 with a Circle d 4800 stall 8 inch tc.
Rearend is stock but with lca's and Comp E adjustable shocks on a stock torque arm.
275-50-15 mickey drs on prostars. i thin the sizee may be hurting me.?
I was pretty happy with it so i checked the plugs and put the 150 jets in but ran out of juice.
Shooting for tens next outing.
Old 04-23-2009, 10:58 PM
98WsSick's Avatar
nice time, and who said 98 ls1's were crap? ha, get a tune and see 10's. Or try the 150
Old 04-23-2009, 11:07 PM
Exactly mine has 135k on stock internals. iam doing a cam swap so i will tune it then.
But do plan on running the 150 soon.
i want 11.50s on motor and 10.50s on spray.
If the engine holds out through the summer iam doing a front mount setup this winter, and shooting for 9s on e85.
Old 04-23-2009, 11:25 PM
jetlag's Avatar
How are you launching? What rpm? That 60ft seems high.
Old 04-23-2009, 11:40 PM
footbrake to around 3000-3500 dont remember excatly maybe less. on 18.5 psi in the back and 35 up front.
the 1.60 felt awesome. iam sure i could get it lower if i tinker some but dont want to blow the rear apart.
my window switch is set at 3200-6200. rev limiter at 6500.
Old 04-24-2009, 06:33 PM
TA1364's Avatar
Nice!! You did a lot over the winter. Cant wait to get back into ls1 when I come back there.
Old 04-25-2009, 12:01 PM
Yeah i still have some more work to do also, like cam, subframe connectors, and some more weight. and just dial in the car better.
I am glad i didnt lose mph an picked up half a second.
Quick Reply: 11s on spray.
