11 Second Club Snake eyes are a good thing
383 build..
Old 11-19-2009, 10:09 PM
Justin Gibbons's Avatar
Default 383 build..
Hey guys, looking for some advise on what size cam I'll need to get me into the mid to high 11's, but still make good power down low. I am building a 383 stroker, using afr 215 heads and a bbk 80mm tb and intake, 3.90 gears and is a m6.
Old 11-20-2009, 07:33 PM
anyone...
Old 11-21-2009, 08:47 AM
RARON455's Avatar
On a 383 with those heads,With a good cam I would guess somewhere around a 228-230 with around .580 or more lift, you should hit mid elevens easily.
Old 11-21-2009, 09:37 AM
johnster's Avatar
383? u need more cam than 228/230 4 sure
Old 11-21-2009, 08:57 PM
what will it take...would like to hear from some M6 guys....what would it take?
Old 11-22-2009, 02:23 AM
blackls1ta00's Avatar
i use a g5x3,234/242 600/610 havent had 1/4 mile run yet though
Old 11-22-2009, 07:45 AM
big dave's Avatar
I'm not too sure what size cam you need but you should be able to reach your goals fairly easily cam only. A well set-up 383 should get you low 11s to high 10s. Sorry I couldn't answer your question. Good luck to ya.
Old 12-05-2009, 11:32 PM
fatmat80's Avatar
you should be using atleast something in the ballpark of a ms4,vindicator,or t-rex..just my opinion
Old 12-06-2009, 01:14 PM
MASS seller approved
smok'nZ's Avatar
t-rex+ and bigger
Old 12-13-2009, 02:39 PM
franksaltz28's Avatar
I went with the ms4. i havent got it tunned yet, but its torque is amazing. I should have it tuned and driving next week. ill let you know any more info when i take it to the track. Hopeing for low 11s.
Old 12-13-2009, 02:57 PM
Hawk170's Avatar
what size injectors are you running ?
Quick Reply: 383 build..
