New best!...cam only...
I went to MIR today. This is my second time out with the cam. The first time out went a best of 11.72 shifting at 6200rpm. I had the shift points raised to 6950rpm 1-2 shift and 7000rpm 2-3 shift. Its crossing the traps around 6000-6200rpm. Race weight was 3600lbs, runners up front and 17s out back. Any way here are the break down of the 3 best passes.
-673 DA
60ft 1.529
330 4.615
1/8 7.209
MPH 94.48
1000 9.470
1/4 11.390
MPH 117.19
-805 DA
60ft 1.519
330 4.590
1/8 7.186
MPH 94.07
1000 9.452
1/4 11.372
MPH 117.30
-805 DA
60ft 1.496
330 4.575
1/8 7.174
MPH 94.05
1000 9.444
1/4 11.370
MPH 116.88
Best mph of the day was 117.60...
MODS:
Pacesetter long tubes
Pacesetter ory
Borla cat-back
Slp blackwing lid
160 stat
FTRA
Ported throttle body
Ported ls6 intake manifold
Slp 85mm maf
March underdrive pulley
237/242 .605/.610 112lsa cam (ms3)
Stock 6spd/ 3.42 10bolt rear
FTI 4k stall
275/40/17 Mickey Thompson drag radials
Weld Draglite front runners
Qa1 coilovers w/ 300lb springs(at 5 clicks)
Slp boxed sfc
Spohn non-adj panhard bar
Stock torque arm
Stock lca's
Stock rear sway bar
Stock rear shocks
-673 DA
60ft 1.529
330 4.615
1/8 7.209
MPH 94.48
1000 9.470
1/4 11.390
MPH 117.19
-805 DA
60ft 1.519
330 4.590
1/8 7.186
MPH 94.07
1000 9.452
1/4 11.372
MPH 117.30
-805 DA
60ft 1.496
330 4.575
1/8 7.174
MPH 94.05
1000 9.444
1/4 11.370
MPH 116.88
MODS:
Pacesetter ory
Borla cat-back
Slp blackwing lid
160 stat
FTRA
Slp 85mm maf
FTI 4k stall
Slp boxed sfc
Stock torque arm
Stock lca's
Stock rear sway bar
Stock rear shocks
subscribing cause i have the same cam and will be installing a couple of the same mods at the same time(p&p tb, pulley). Those are some great times. They yell at you for not have a cage???
Thanks man...It's def in need of some suspension,the passengers side is squatting/leaning bad. I'm not sure if I want to do a drag bar. I know the drag bar would be better for the track. For some reason I'm more leaning towards a 1 inch sway bar. I'm not sure though....
I'm not going to be able to make it to the track tomorrow, so I will be going to a rental next week. It will be my last track day for the year. Prob going to pull about/near 100lbs out. Also today I fab'ed up a duct that attaches/bolts to the FTRA, it looks similar to ssra. So hopefully those two things help, and maybe just maybe I might see 11.1. We shall see.....
