s-10 with 5.3 in 11's
89 stock suspension s-10 with a stock rear and slapper bars and drag radials and skinnys. It has a stock 5.3 with a 224 cam carb intake and exhaust manifolds. it has a turbo 350 trans with a 4000 nitrous converter and with a 100 shot it went a 11.58 spinning. the next pass i tore up the rear end
http://www.youtube.com/watch?v=ZT4rE...layer_embedded
well i was lucky. now i am building a 9" and hoping for the 10's next time out. once i get the suspension right i will be there easily
it had a stock 10 bolt with 3.42's and 28 spline axles and was cutting a 1.69 60 foot on motor and went a 1.65 on the bottle spinning the whole 60. so it has a whole lot better 60 left in it. it went a 7.8 on motor but it has a big 4000 nitrous converter. the 11.58 pass was on a low bottle spinning alot, so next time it should do the job
Here's a video of my truck bad pass hit the rev. limiter going into 2nd went 6.95 this pass
http://www.youtube.com/watch?v=9FaYGV1tiww
the bed is dented, in the vid if you check it out close it hit the bed 3 times sames spot haha ill post some pics of my truck before. LS___10 could you pm me the compression and all of your motor? id like to know more details
got the truck back together tonight and on the ground and the corner of the truck that hit the ground is an inch lower then the other side. same air pressure, all is the same. i have no idea
