11 Second Club Snake eyes are a good thing
From 100% Stock LS1 to 11sec LS1 T/A Mod List
Old 07-06-2010, 03:30 AM
MAXXLIMIT's Avatar
Arrow From 100% Stock LS1 to 11sec LS1 T/A Mod List
Ok guys, I bought this car when it was 100% stock and I mean STOCK!!!! That was cool for me because I got to see what it would do from stock to when I got my stuff done. Below I will show what it did stock and then what I did after and what it did then. I hope this helps some people see some differences. On the modded side all the parts are brand new and the swap and tune and break-in period of driving and going to the track to test for after results were all done in a month!!!
Stock setup:
1998 Pontiac Firebird Trans Am
LS1/A4/2.73 Gears/90k on body, 30k on motor
Any upgrades:
MAGNAFLOW MUFFLER
Dyno Numbers:
Track Times:
2.1 60FT
106 MPH
13.8 ET
Modded setup:
Any upgrades:
LS6 Intake Manifold
SLP Air Lid
K&N Air Filter
Ford Motorsports 42# Injectors
MTI S1 Cam, 244/244 Dur, .612 int/.612 ext. Lift @.050, 112 Lsa
TrickFlow 7.400 Pushrods
Patroit Performance Stage 2 "243" P&P CNC'd Cylinder Heads
Pacesetter Long Tube Headers
Pacesetter y-pipe
Cats Deleted
Cut out installed
Yank SS4000 Torque Converter
Transmission Cooler
UMI Chassis Mounted Adj Torque Arm (set at -2 deg)
BMR Tubular Control Arms
BMR Non-Adj Panhard Bar
Motive 3.73 Ring & Pinion Gear Set
255/50/16 Mickey Thompson Drag Radials (18psi)
Race Weight With Driver 3730lbs
Speed Density Tuned
Rick Hollenbeck at Synergy Motorsports in Fremont, CA
Dyno Numbers:
414rwhp/403rwtq
Track Times:
1.68 60ft
7.57 et 1/8th mile
93.50 mph 1/8th mile
11.77 et 1/4 mile
120.66 mph 1/4 mile
DA for the day was +1975ft
mid to high 80's
300lbs driver
Want to thank:
Rick at Synergy Motorsports
Dave at Yank Torque Converters
Few of the local guys and track guys (Brandon, Eddie, Josh,)
Family and Friends:
Wifey Lesley
Brother Tino (Tnmotown)
Cusion Chris Walker
Friend Fonz
Friend Danny
Friend Paul
We are just putting together a 11sec DD and then get ready later this fall for mid to low 10's. We just have fun doing what we do and enjoy it. .
Old 07-06-2010, 03:38 AM
MAXXLIMIT's Avatar
And I know I'm holding some tenths back. I think with a better DA, driver loose 50lbs (lol), put the DR's psi maybe down to 15psi, and a better intake for the cam and the air supply it needs after 5,200rpms maybe just maybe 11.3-11.5's????????
Oh and this is all on Chevron 91 octane pump gas here in California.
Old 07-06-2010, 07:39 AM
TXZ28LS1's Avatar
dang MAXX,
definitely has came a long way man!!
Old 07-06-2010, 08:10 AM
blk/slvr02ss's Avatar
All u need is to get your 60ft times in the 1.5 and u can be low 11's.
Old 07-06-2010, 08:39 AM
BMR Tech's Avatar
Nice pass...
Would have to agree get the 60' down and it will be rollin.....
Old 07-06-2010, 08:42 AM
EZZZE's Avatar
Very nice.....especially the mph!!!
Old 07-06-2010, 02:53 PM
MAXXLIMIT's Avatar
We'll see what the new 102mm FAST Intake and 102mm TB does for the cam and also the new underdrive pulley. All got ordered today from Texas Speed!!
Thanks John for the tech help!!!!
Old 07-06-2010, 03:18 PM
99'CajunFirehawk157's Avatar
Default ??
So your running 42lb injectors on a stock fuel pump setup
Old 07-06-2010, 03:48 PM
MAXXLIMIT's Avatar
Yeah!
Old 07-07-2010, 09:03 AM
Mac 2002 SS's Avatar
WOW !! that mph is insane !! your car is pulling like madd on the top end !!
Old 07-08-2010, 06:09 PM
ls1curt's Avatar
real good mph, congrats
Old 07-08-2010, 10:05 PM
Mike Morris's Avatar
Nice job!!!
Old 07-09-2010, 12:43 AM
Z28SteveA4's Avatar
thats a great time and mph for that da. If you get better air you will be mid to lower 11's easily. then get that 60 down and the intake on and you will be low 11's no problem man.
Old 07-11-2010, 12:23 PM
1Bad97WS-6's Avatar
Congrats man.. My car bone stock down to the paper filter went
60ft- 2.0
MPH-101
1/4-13.64
Old 07-12-2010, 06:43 PM
jonathan_ed3's Avatar
Wow...crazy. Crazy numbers! With that MPH it seems to me you are probably making way more power or race weight is lower than the scale said?
I mean generally cars that heavy need ~50-80 more rwhp to trap that high.
Old 07-12-2010, 09:48 PM
Redfire 03's Avatar
Wow your trap is crazy for the power/weight. Nice job!
Old 07-13-2010, 01:03 PM
1999WHITEFRC's Avatar
I went 11.13@123 with a stock fuel pump,and 42's. Congrats! Great times the 120mph is killer for that weight. My car was #3230 with me in it on the scale at the track,at a scale close to home it was 3180. So they do differ in weight. Im curious to see if the 102/102 helps. I bought my 102 because the 92's were all but gone,and it was the same price if not cheaper.
Old 07-13-2010, 06:28 PM
cacmanjr's Avatar
Modded setup:
No problem with piston to valve clearance? Are the valves in the 243's recessed into the head?
Old 07-18-2010, 12:05 AM
z28241's Avatar
He should of cleared just enough nicely in the PTV, if the heads weren't milled and stock gaskets...BTW OP..u didnt mention your rim set up, ..those stock heavy 16" rims..curious..? No Sub-frame Connectors either? BTW Nice numbers!!
Old 07-20-2010, 02:12 AM
MAXXLIMIT's Avatar
Thanks,
When i go to the track I use the 93-97 camaro snowflake wheels with a 255/50/16 M/T DR's, No Sub-frame connectors.
Quick Reply: From 100% Stock LS1 to 11sec LS1 T/A Mod List
