11 Second Club Snake eyes are a good thing
Im i close to the 11's
Old 06-24-2011, 12:42 AM
rollingchevys's Avatar
Default Im i close to the 11's
i have a 2000 Z28 LS1 it has patriot LS6 heads, tr224 cam ,LS6 intake, 42lbs injectors, long tubes headers 1 3/4 . it has a 3600 stall, 3.73 gears 30k miles on "the motor car went 12.7@110 stock with a converter"
i was wondering if im close to the 11"s car weight 3500lbs
Old 06-24-2011, 07:23 AM
Mystery Bird's Avatar
I'm running 11's at 3700lbs with me a 1/4 tank of gas. You should be there, only one way to find out.
Old 06-24-2011, 07:40 AM
blk/slvr02ss's Avatar
Mid 11's as long as the car hook's !!!!!!!
Old 06-24-2011, 08:39 AM
Head Hunter's Avatar
Need tire but that converter will help
Old 06-24-2011, 08:46 AM
Stippy17's Avatar
I have similar mods and I've ran a best of 11.76 @ 115 to give you some sort of idea.
Old 06-24-2011, 03:09 PM
car hooks real hard on the street im running M&H's 275/50R17 this tires work better then nittos or MT's car pulls so hard all around has some real top end i just hope i run a 12.0 or HIGH 11's
Old 06-24-2011, 03:11 PM
i did a street tune have no idea on HP numbers but the car feels real strong
Old 06-25-2011, 03:33 PM
BODUKE's Avatar
With a drag radial you should be in the 11's.
Old 06-26-2011, 11:42 AM
Mike Morris's Avatar
Easy 11 sec car
Old 06-27-2011, 12:04 AM
will see soon! i only have and 1/8 mile track close to home if the car is somewhere in the 11's what should i ET in the 1/8 and MPH
Old 06-27-2011, 10:34 AM
chevyconvert's Avatar
Through my limited experience, anything below a 7.60 in an 1/8 mile should pull below a 12 second pass in the 1/4.
Old 06-27-2011, 11:41 AM
01BlackCamaroSS's Avatar
That setup should be good for some where around 11.70s just put some drs on it so the cars hooks and you should be there
Old 07-26-2011, 09:09 PM
my car went 7.8@90 in the 1/8 the car dirent want to go into 3rd gear had a 1.8 60ft car dirent want to stall more then 1500RPM there somwthing wrong with my tranny or converter
Quick Reply: Im i close to the 11's
