11 Second Club Snake eyes are a good thing
So close to my goal I can taste it...
Old 11-13-2011, 11:47 AM
KC Henry's Avatar
Default So close to my goal I can taste it...
My goal is to have Christine (my Caprice) be a Cam-Only 11 second granny tank. I just need to work out a couple more bugs and I have no doubt I will be there.
A huge thanks to all my friends that have helped my along the way, including donating their time, trailers, trucks, knowledge, parts and money to help me get the car where it is today.
http://youtu.be/xuBgEhOlR0E
Thank you for looking.
Tags: EPS, Cam, LQ9, Caprice
Old 11-13-2011, 04:22 PM
ten5nova's Avatar
Damn son, that boat gets with it!! Give us more details on the 6 liter. I bet if you shed a little weight from the car it would get in the 11's pretty easy. Nice work sir!!
Old 11-13-2011, 04:43 PM
KC Henry's Avatar
Thank you for the kind words. I enjoy the challenge of making a heavy granny tank move well.
The LQ9 6.0L is a Cam-Only set up, Stock/Untouched "317" heads....NO L92 head swap with a $1,000+ Fast Intake and claiming "cam-only" here.
I am using an EPS cam and really like how well it pulls. The car has a TH400, 4500 stall, 3:73 rear end and the cheapest Trans Am headers I could find, all helped by a nice set of Mickey Thompson ET Street Drag Radials.
The 12.0 run was just letting off the brakes and hitting the gas, didn't stall it on the foot brake or anything.
I am having an issue with the trans, it some how shifts it's self from 1st - 2nd by its self really early (about 4,500 rpm as you can hear in the video) even when I shift the gears manually (the 2nd to 3rd gear shift will stay until I shift it manually at about 6,500 rpm).
I know the pass that I snapped my axle on would have been a high 1.5 60ft and an 11 second pass because I actually stalled it up on the foot brake before launching that time and it launched haaaard.
Snapping axles just means it's hooking up really well I guess.
Old 11-13-2011, 04:51 PM
ten5nova's Avatar
Wow, that's pretty quick with not a lot of mods!! Sounds like the usual drivetrain stuff as well. I know all about the heavy car situation, my disco Nova isn't exactly light!! Any power adders in your future plans?
Old 11-13-2011, 05:06 PM
KC Henry's Avatar
Thank you very much. I know I would go faster with a swapped Fox Body Mustang or RX7, but I like the feeling of getting all the heft and weight moving in an older heavy car.
After I get the transmission and rear end issues/bugs worked out and am running 11's consistently, then I will spray a 150 wet shot on it. The system is already on the car, just not hooked up completely yet.
Old 11-13-2011, 08:19 PM
green28's Avatar
Nice car and good run. Car sounds good. I learned to drive in a 4-door 79 with a 305. Do you know how much that beast weighs?
Old 11-13-2011, 08:24 PM
KC Henry's Avatar
Thanks! I learned to drive on this car when it had its stock 350, so I know where your coming from.
Last time I had it at the scales it was with the all aluminum LS1 and TH350, and it weighed in at 3,860 with me in it. Now that it has a LQ9 (iron block) and a TH400, it is probably closer to 4,000 lbs (2 tons) with me in it.
Old 11-13-2011, 09:51 PM
A.R. Shale Targa's Avatar
That car rules man !!!! I recently sold a primered green 69 Imp 4dr. post car
that had an s475 blo-thru on a 385 and the looks you get from the fans in the
stands are priceless when you come back the return road. I'd bet people flock
to it in the pits just to see the hood opened....
Old 11-13-2011, 09:57 PM
KC Henry's Avatar
Thank you for the kind words. It does draw a crowd after the hood gets popped, and I love the look on peoples faces when I start the car and they hear the exhaust and how it lopes, or after a race...it is priceless.
Old 11-18-2011, 12:24 PM
ten5nova's Avatar
Your 6.0 would fly in a fox mustang, but that's been done to death already, the Caprice is ******' cool!!! I've never seen a caprice with an LS swap before. Should be interesting to see what it does on spray, I plan on spraying my 5.3 next summer, maybe a 200 shot. Good luck!!
Old 11-18-2011, 04:33 PM
KC Henry's Avatar
Your 6.0 would fly in a fox mustang, but that's been done to death already, the Caprice is ******' cool!!! I've never seen a Caprice with an LS swap before. Should be interesting to see what it does on spray, I plan on spraying my 5.3 next summer, maybe a 200 shot. Good luck!!
Thank you, I really appreciate it!
I bet a 200 shot on your 5.3 will be very impressive.
Old 11-19-2011, 01:17 AM
ten5nova's Avatar
You're welcome, I love odball cars that haul ***, probably why I have a disco Nova!!
If I can make it to the track on a day with some decent air, I'm looking to run some low 11's on spray. I'd like to get in the 10's with this engine, but it might take more than 200. We'll just have to see I guess.
Old 11-19-2011, 08:09 AM
KC Henry's Avatar
I agree, there is just something about odd ball cars (non-sports cars) getting the job done that I really like.
I have no doubt you will reach your goals with the 5.3 in your disco Nova!
Old 11-19-2011, 04:33 PM
BODUKE's Avatar
Good run keep trying you willget there!
Old 11-19-2011, 08:15 PM
KC Henry's Avatar
Originally Posted by BODUKE
Good run keep trying you will get there!
Thank you man!
Old 12-10-2011, 12:44 PM
WonBadZ28's Avatar
That's a awesome ride man! Give you credit daring to be different! It's working and you will see 11's in no time!
Old 12-10-2011, 12:52 PM
KC Henry's Avatar
Thank you greatly, I can't wait to see 11's on motor consistently and then it will be time for a 100-150 wet shot.
Quick Reply: So close to my goal I can taste it...
