11 Second Club Snake eyes are a good thing
11.6 @ 118 :)
Old 08-24-2012, 08:41 PM
Huggerorange73's Avatar
Default 11.6 @ 118 :)
Here's the info & slip :
Year : 98 Corvette A4
Tires used on the pass : MT Drag Radials 275/40/17 @ 20 PSI
Performance Mods (if any):
A & A supercharger kit (supplied pulley)
Ported Throttle Body
LS6 Intake
Texas Speed & Performance Long Tubes & Off Road mid pipes
Corsa Indy Pace Car Exhaust
FLT Level V transmission
Yank 3200 stall
Tune
60'.............1.759
330'...........4.890
660'...........7.475
660’ mph...94.58
1000'..........9.735
1320'..........11.635
1320’ mph…118.90
Name of the track: Great Lakes Dragway
Weather : 71 & clear
DA : 1723
Notes: 3:15 gear
Slip:
Old 08-25-2012, 12:39 AM
work in progress's Avatar
If the car in your sig goes with that time slip, something isn't adding up. My SS is heavier, less aerodynamic, suspension isn't setup too well and my slips are about the same as yours if not a bit faster in a 2600-3000 ft DA. MPH should be mid 120's+
Old 08-25-2012, 07:35 AM
Mac 2002 SS's Avatar
congrats on the new best !! it will only get faster .
Old 08-25-2012, 08:51 AM
blk/slvr02ss's Avatar
Better 60ft and lower DA should be very close to the 10's.
Old 08-25-2012, 09:27 AM
murphinator's Avatar
that da is pretty bad , a nice fall da in the -500 to -1000 below sea level will get you real low 11's and like the guy above me mentioned tighten up that 60 foot and you got yourself a 10.9
dont forget to update your avatar to 11 sec club
Old 08-25-2012, 07:43 PM
SAPS's Avatar
Do you know what the DA was?
I'd expect a higher MPH on a supercharged LS1.
Old 08-25-2012, 08:33 PM
garygnu's Avatar
you should be making good low end power .if you are spinning you will need some better shock and springs.work on hooking up and you will be flying.try removing the front sway bar.
Old 08-27-2012, 05:53 PM
Agreed.....this was the first time down the track with this set up.....still some bugs to be worked out.
I'm hoping!
I'm thinking this thing has a 10.9X hero pass in it...we'll see.
Will do! DA was 1726....was 87% humidity.
Me too....that's why I went into panic mode after I saw 118.
Thanks for the info!
Old 08-27-2012, 08:13 PM
Mike Morris's Avatar
Nice job. In cool air and with some decent traction you have an easy 10 sec ride.
Quick Reply: 11.6 @ 118 :)
