11 Second Club Snake eyes are a good thing
New Best with some shifting issues
Old 11-16-2012, 09:18 PM
10 Second Fun Car
jlrz28's Avatar
Default New Best with some shifting issues
11.48 @ 119 1.58 60'. Got something going on with the shifting towards the end of the runs. It starts shifting allover the place.
Old 11-19-2012, 09:37 PM
prokilllsx's Avatar
Nice! More details on shifting issues?
Old 11-19-2012, 11:01 PM
10 Second Fun Car
jlrz28's Avatar
At the end of the track when in "OD" it starts shifting up and down. When it's in "D" it does the same thing just not as bad.
Old 11-19-2012, 11:16 PM
prokilllsx's Avatar
Any chance you are hitting the rev limiter? or maybe sucking the pan dry?
Old 11-19-2012, 11:20 PM
10 Second Fun Car
jlrz28's Avatar
Tried raising the rev limiter and adding almost a half quart more transmission fluid.
Old 11-20-2012, 10:57 AM
Beave's Avatar
Nice pass. Im curious to see whats causing that shifting issue. I also ran my best this weekend hitting the limiter on the 2-3 shift.
Old 11-20-2012, 03:12 PM
NC98Z's Avatar
Why don't you run a taller tire so you don't go into OD before the line?
Old 11-20-2012, 03:42 PM
Beave's Avatar
I dont think he said its shifting into OD. I believe he meant he tried running in both D and OD and it still does the same thing.
Old 11-20-2012, 05:47 PM
prokilllsx's Avatar
I hope it's not the transmission getting weak.
Old 11-20-2012, 05:57 PM
10 Second Fun Car
jlrz28's Avatar
If it is the tranny, bigger stall and better transmission!
Old 11-20-2012, 08:18 PM
Old School Heavy
speedtigger's Avatar
Any chance it was the lock up in the torque converter?
Old 11-24-2012, 09:44 AM
10 Second Fun Car
jlrz28's Avatar
Here is a video, man the difference between the 3.25 and 3.75 was night and day.
Old 11-25-2012, 03:31 PM
10 Second Fun Car
jlrz28's Avatar
Well after letting Pat G look at the logs from the runs, found that the throttle was only at 75% at wide open throttle. Which would allow the converter to lock up and not full line pressure. Found the adjustment clip loose. So I readjusted it. I guess I found a free mod for more power.
Quick Reply: New Best with some shifting issues
