Hit 11s but disappointed...
So I got my huron speed turbo kit with 76mm on the car and mad a few passes. First of all I had to drive forever in 92* heat sitting in traffic. The car had no cool down time. I hit 11.6 @ 120 with a 1.9 60'. My IAT was 142 on that pass and my ECT got to 243. Obviously my cooling system is insufficient and I need to install my griffin vertical radiator.
I have commanded 15* of timing in boost but it was pulling 6* so I made that pass on 9* timing. I believe the car should be a lot faster when I get these issues fixed.
Mods:
JY 5.3
Ls6 cam
Ls6 intake
Huron speed turbo kit
76mm turbo @ 9psi.
Mods:
JY 5.3
Ls6 cam
Ls6 intake
76mm turbo @ 9psi.
That hot weather was a major factor. The blessed thing is you drove it home and it was'nt on the back of a flatbed! Once you get the issues addressed you will go faster. Not to many cars gone go that fast in 92 degree weather.
Does your track have a water hose you can use to cool the car with? I know too late now, but thats always an option when everything is that heat soaked.
Living in Reno, I assume it's going to be like this until Oct?
Why no intercooler? Meth injection?
Probably a good thing the IAT table is in use.
Ron
Ron
Ron
Ron
My IAT sensor is about 5-6" back from the TB, do people usually spray the meth before the IAT ?
I have an intercooler on the car. It's probably a 26x12x4" intercooler. I didn't check for a hose. The track is down in Sacramento. I'm getting ready to put a snow stage 2 in the car. The car was just heat soaked running for 6 hours prior to hitting the track with no real cool down time.
You have to let it cool down. The track wasn't working very well either and everyone was slow. That car would easily go bottom 11s if you can get that 60 down though. Lose about 3-4 tenths and you'd be 11.0~11.2 possibly has a 10 in it on a better day.
Spray meth before the IAT. Was your timing in boost set at 15 and the IAT was pulling 6 more? 9* is not a lot of timing at all, but 142* is a pretty high iat.
My timing in full boost is 15* but my IAT and ECT spark correction tables were pulling 6 degrees due to the high IAT and ECT temperatures.
I need to tweak my suspension as well. I didnt have my front struts set on full loose which wouldve helped my launch as well. I tried launching a little harder the next time and it blew the tires off. I need to drop the psi down in them some more and that should help. I'm running 315/35 ET street radials.
Anyways, It was ok for what it was. I know the car has more in it on the same boost level but maybe next time I can get the times down.
Yeah I will definitely have some ice handy. I plan to install a snow stage 2 kit before the next track day so I can imagine that will help a lot. I'm trying to figure out the best way to launch the car where the turbo spools the quickest. Slipping the clutch a little bit seems to work the best since it loads the engine and creates boost.
I know a launch controller will work the best...but i'm looking for ideas without that for now. Methanol is the first thing on my list and then a 2 step launch controller.
