11 Second Club Snake eyes are a good thing
Took me a year but 11's are here!!
Old 01-01-2014, 02:07 PM
mgood613's Avatar
Default Took me a year but 11's are here!!
1999 Camaro Z28
140,000 Ls1 short block
PRC Stage 1 Milled .030, .040 cometic ARP bolts
Howards VS ASA cam 226,236 .525 110 LSA
LS6 Intake, 85mm throttle body, 85mm MAF, SLP lid
160 Thermostat, Powerbond Underdrive pulley
Monster Stage 2 clutch, 10 bolt 3.90 gears (welded, solid spacer, arp studs, T/A cover)
Subframe connectors, torque arm relocator, full poly mounts, bmr torque arm and rear suspension
Mickey Thompson E/T Streets 26 10 16 Bias Ply
Ran my First 11 second passes, with a best of 11.684 at 121.53
I must say it was my first time on Bias Plys also, that took some getting use to.
Now I just need some weight reduction and a stronger axle! Aiming for 10's next year.
Track was Lapeer Dragway, 300 DA
Attached Thumbnails Took me a year but 11's are here!!-track-times-10-27-130002.jpg   Took me a year but 11's are here!!-track-times-10-27-130001.jpg
Old 01-01-2014, 02:47 PM
HCI2000SS's Avatar
Not bad man! You full weight? Who tuned your car if I may ask? What do you make for power? I wanted to make Milan or Lapeer before they closed this year, but I just got the car back late August, and wanted to let the motor break in more before hitting it hard
Old 01-01-2014, 03:08 PM
mgood613's Avatar
I have the front sway bar,spare tire, jack, air pump, and egr removed.
Rich Gala at motorcity speed dyno and street tuned it.
427rwhp 390ftlbs
I like Lapeer because you can get a ton of runs in and I could get use to launching the car. One day I got 28 passes. lol
Holloway5's Avatar
Get that 60ft down and you'll be happy with the results. Your trap speeds pretty nice, definitely more left in it.
Old 01-01-2014, 03:16 PM
HCI2000SS's Avatar
Very nice! Yes I agree with you about Lapeer lol. I like their tech inspect...that there really isn't much of one lol. BTW, that's a really good trap speed for 427 rwhp and mostly full weight
Old 01-01-2014, 04:16 PM
mgood613's Avatar
I have plans for a 9in, I was slipping the clutch from 3000 with 20 psi in my mickey Thompson's. Praying that the stock 10 bolt would hold. LOL
I am a hard top car, cloth interior. I need to run it over the scales. I would love to gut the abs, a/c, front and rear supports. I like a/c too much! LOL So that's not going to happen.
Old 01-06-2014, 10:02 PM
Elwood617's Avatar
That is awesome, only thing holding you back right now is the 60'
Quick Reply: Took me a year but 11's are here!!
