11 Second Club Snake eyes are a good thing
11.5 @ 116
Old 10-22-2014, 08:22 PM
babbage1109's Avatar
Default 11.5 @ 116
Went to the track for the first time on this setup d.a. was 422ft
Old 10-22-2014, 08:50 PM
murphinator's Avatar
nice job! only thing weird I see on the slip is picking up only 22mph in the 2nd half , how is it geared ? for that matter the next post will likely be whats it got for mods/setup so you may as well put it out there lol your dyno numbers are more than a bolt on car.... heads/cam car ?
Old 10-22-2014, 08:57 PM
Mods:
ls1 stock cube
12:1 compression
Tick polluter cam
ported milled 5.3 heads
underdrive pulley
fast90/90
ftp lid
rpm lvl 5 trans
ptc 4000 stall (used & the cheapo version)
2.73 gears
275/40/17 bfg drag radials
stock shocks/springs
Weight reduction: mwc kmember/ ac removed
Old 10-22-2014, 09:00 PM
HCI2000SS's Avatar
Given your suspension and tire setup that's pretty good IMO!
Old 10-22-2014, 09:02 PM
i was honestly surprised it went this quick haha
Old 10-22-2014, 09:09 PM
NW Iowa WS6's Avatar
2.73 Gearing explains the weak back half, 3.23+ would really wake it up, i bet a 10th in the 60, 2-3 10ths and mph in the 1/8th and 3-4 in the 1/4, with a cam your really ******* it in 3rd gear below your powerband
Old 10-22-2014, 09:26 PM
rear end and suspension are the next thing up
Old 10-22-2014, 09:52 PM
just read another post on here 273's and the guy trapped 121 holding 2nd through traps , did you shift into 3rd? that would tie into what NWIowaWS6 said about explaining the weakish 2nd half.
Old 10-22-2014, 10:06 PM
I'm sure I did. Tonight was the last track day for the year. Winter plans are getting a new rear and 3.70-3.89 gears. So hopefully that helps out.
Old 10-23-2014, 07:34 PM
Head Hunter's Avatar
I had a H/C T/A putting down 450/415 that ran 7.447@95mph and 11.539@119 with a 1.75 60' and I had 3.73s - will the gearing really change his mph that much?
Old 10-23-2014, 09:10 PM
It should yeah, hes sandbagging it accross the line in 3rd with those 2.73s at like 5000 rpm, his car has probably 50 more hp at 6000+ than there where he would finish with 3.73s
Old 10-25-2014, 01:08 AM
DREAMZ28's Avatar
Yup, my car with 2.73s fell asleep at the 8th. Went 12.9 @ 104 but was going 8.17 in the 8th. And that's with a stock motor.
Old 10-26-2014, 01:45 PM
01ssreda4's Avatar
We have similar mods/times/DA. Check it out:
https://ls1tech.com/forums/multimedi...pics-vids.html
Old 10-27-2014, 03:46 PM
Sales@Tick's Avatar
Congrats! A set of 3.73's would really wake that thing up! Heck throw some 4.10's in it!
Old 10-28-2014, 06:50 AM
thanks! shes def going to get a few things done this winter. hopefully drop down to the 11.0s by the end of the race season next year
Quick Reply: 11.5 @ 116
