11.61 @ 115.9 mph *video inside*
Gives me confidence I can hit my goals with a properly efficient setup.
Great run. I'd say the lacking top end is from the lack of ram air, probably just wants to breathe since it seems to be flowing so well. Get that ram air setup on there and get an 11.3/4 out of it.
Any chance you know the weight? If not, a quick rundown of what's not in the car?
Edit; Should get yourself in here;
https://ls1tech.com/forums/drag-raci...1-74-bump.html
- Drew
- Drew
The car in the OP is very near stock and is doing 1/8th mile times and traps as good as this built motor heads/cam car(also terribly random that you made a tiny comment just to link your own thread/car).
I realize you're letting off at the end, but the 1/8th mile is near identical to this bolt ons stock motor car. Terribly confusing.
Check the tune up on that car. Make sure you're getting 100% out of it.
- Drew
Op.....what was the d/a like on those passes? Those are some very impressive times for your mods......great .60 ft. times and mph seems right for an auto with a big stall. And I have similar mods to Johnny 59 so i can relate and compare also, I don't see anything wrong with him posting that.
thanks Dad!
Im not sure of the weight of the car, nor the DA that night at the track. It was a cool night though, like in the lower 70's/upper 60 degree weather.
I'm happy with that ET for the basic bolt-ons. Heck, I was still missing an under drive pulley, ram air setup, and wasn't dyno-tuned. But I can only guess what those times would be, since I've changed setups now.
#32
What was the track and what date? DA can be looked up.
If your unsure the weight can you throw out a quick list of what's not on the car anymore?
Still really impressed with this.
Edit;
Never mind. Based on the video and time slip I figured it out.
DA at your strip, that day at that time was 666ft.
Making that time even better. It's a good DA but it's not negative and I fully expected it to be. Awesome.
- Drew
Edit;
- Drew
