11 Second Club Snake eyes are a good thing
Running 11's - How hard is it? What's your story?
Old 03-15-2015, 11:18 AM
  #81
senicalj4579's Avatar
Mine got 11.9 stock internal. ss3600 stall, boltons, mt drs, stock 3.23 gear, 3500lb raceweight.
https://ls1tech.com/forums/11-second...id-inside.html
Old 03-16-2015, 05:52 AM
  #82
typedRew's Avatar
New England Dragway Oct 5th 2011 - YouTube
What was the 60ft on that? DA?
Looked solid for being on big wheels and not much weight out of it.
- Drew
Old 05-07-2015, 04:20 AM
  #83
scotty2000ss's Avatar
Nice run. Man the DA affects times a lot more than I thought. Best I've raced in was 500.
Old 05-07-2015, 05:51 PM
  #84
ASSuming On The Tree
audacious nick's Avatar
Buy a GTR, launch mode on, instant 10s-11s while you eat a sandwich.
Old 06-26-2015, 10:41 PM
  #85
Bump
Old 07-20-2015, 07:51 PM
  #86
WTF?'s Avatar
Stock c5z, vara-ram, M/T 305's....untuned. 11.9 Got a vid somewhere, can find and post if necessary.
Old 07-21-2015, 05:02 AM
  #87
Post up!
Old 07-28-2015, 08:34 PM
  #88
Bitemark46's Avatar
Originally Posted by scotty2000ss
Post up!
Scotty you have mph to hit 11's. Just need some traction. cut that 1.9 down to a sub 1.6 and I bet it'll go 11's.
2 ways to run the number. You either do it by mph (easy way out IMO) or do it with traction. 116 traps is easliy a 11.7 or 11.8. Get all the weight you can out of it and put a sticky tire on it. If it breaks it needed to be replaced anyways!
-Mark
Old 11-13-2015, 10:32 AM
  #89
Figured I post in here one last time seeing the car is sold now.
I never ended up running 11s. Best was a 12.3 with a 1.8 60ft. I learned alot from the experience and hearing everyone's feedback was great. Here's why I think I couldn’t achieve it.
1. Car was over cam'ed.
2. Ls7 clutch
3. Heavy wheels
4. 10 Bolt
Can’t wait to get into a C5Z next year. I have already planned out my next build and have almost 90% of the parts purchased lol.
Old 11-15-2015, 04:58 PM
  #90
big hammer's Avatar
I had an Ls7 clutch in my car once. I swear it slowed the car down. They're way too heavy
Old 11-15-2015, 07:40 PM
  #91
I had a tune after the install to dry and clean up driveability. I lost power from it. Quite a bit too.
Old 11-18-2015, 09:27 PM
  #92
mjs1012's Avatar
I got 11s with a mild cam/bolt-on/converter and heavy *** s60 along with some minor weight rediction. Best time so far was 11.7/115, but there's more left in the car. If I air down the Hoosiers I use, add an ssra/chris1313 and raise my shift points I think I can get into the 11.4-11.5 range.
Old 04-22-2016, 03:47 AM
  #93
bigteddy254's Avatar
Originally Posted by codyvette
Damn dude. He doesn't know a every aspect of your situation. He gave advise as t what it looked like may be some areas you could look at. A lot of the guys that live in the SRK section talk a ton of **** on one another including Guitar. You got on here looking for advise. If you want to defend your tuner that's cool but try it in a more subtle way. He was jus trying to help you. Good luck on your venture for 11's. It really isn't all that hard but there are a thoushamd ways to get there. Keep us posted when you get there.
03 c5 vette 450hp, stock bottom end stock heads, stock cam, arps on a stock block yes i know i did it, tuned long tubes, ls6intake, bigger maf, ramair, catch can, borla exaust, stage2 clutch, tick adj slave cylinder, clutch, stock rear end gears, 18's front went to fattest 19s in the rear i could hold without a tub, 150 shot, and dyno tune.
11.7@ 115 no nos on toyo proxies, waiting for slicks to use the squirt at the drag =) build was to prove to fools u dont gotta cam and stroke and bore **** to hell or use 4.10s to have a fast car ya know.
Old 04-25-2016, 03:09 AM
  #94
fly pantera's Avatar
The easiest way I ran 11s and I have done it in 4 different cars with mild setups is this way.
1990lx coupe.original 5.0 with 114k miles.
Weight reduction,ud crank pulley, explorer intake manifold, hollowed cats, flow masters,3.73s,lakewoods,upper lower control arms,nx 100shot,slicks and that's it.went 11.4@117
Basically just buy a fox coupe, lose weight buy slicks and spray it and it will go 11s.its that simple and cheap
Old 05-27-2017, 10:50 PM
  #95
Bump
Old 05-29-2017, 10:18 PM
  #96
Romulus22's Avatar
Stock engine and 3.00 final drive got me 11.3-11.4's
Old 05-30-2017, 07:15 AM
  #97
Jtm2085's Avatar
Never really had a decent tire when I was just bolt ons and would go mid 12's with 2.xx 60ft's. Threw a set of bias plyes on the back and a cam shaft in at the same and got down to a 11.3x's at 124. I have added a 150shot plate kit and swapping to a th400. I hope the changes lower that ET just a hair.
Old 05-30-2017, 08:54 AM
  #98
80/TA/LT1's Avatar
Anybody in here got a link to hiossilvers build thread?? Ya'll got me curious now....
Old 05-30-2017, 09:24 AM
  #99
Wasn't aware he made a build thread.
Send him a PM. He's normally really helpful when you do.
Old 05-30-2017, 02:31 PM
  #100
HioSSilver's Avatar
I've never made a build thread. Everything has mostly been a running change.
Quick Reply: Running 11's - How hard is it? What's your story?
