11 Second Club Snake eyes are a good thing
Think I will be in the 11's?
Old 03-29-2015, 06:01 PM
Bobs-00-SS's Avatar
Default Think I will be in the 11's?
2000 Camaro is full weight. It ran 12.28 with a 1.9 60ft. It has MTI ported heads, 231/237 cam, Headers, catless y, 4in single and 4.10 gears. This was with a 6 speed. I am doing a 4l60 swap with with Yank 4000 stall converter. I am also adding a tunnel mounted torque arm, ls6 intake, and Frost speed density tune. Any estimates on my ETs? Thanks!
Old 03-29-2015, 06:02 PM
Old School Heavy
speedtigger's Avatar
What was your MPH on the 12.28 pass?
Old 03-29-2015, 06:08 PM
98CayenneT/A's Avatar
You should be able to cut that 60' down to at least a 1.7x with the a4 and converter, in turn putting you at 11.8x just by getting your 60' down
Old 03-29-2015, 06:12 PM
HCI2000SS's Avatar
What tire?
Old 03-29-2015, 06:59 PM
murphinator's Avatar
heads/cam should be high 10's low 11's , plenty of bolt on cars crack 11's
Old 03-31-2015, 11:38 AM
typedRew's Avatar
I would say high 10s with a tire and good DA, low 11s in a bad DA or mid 11s on street tires.
- Drew
Old 04-01-2015, 09:13 AM
codyvette's Avatar
It seems like a full weight street car. Why the speed density tune? That will probably be the deciding factor, good or bad. Is it a bracket car?
Old 04-04-2015, 04:24 PM
scotty2000ss's Avatar
^^^This will help us!
Think he's got it now with a good tire.
Old 05-04-2015, 11:35 AM
Bobs-00-SS's Avatar
I think my Mas air sensor is going out, Deciding to just ditch it now. MPH was 115 and 60' was 1.98
Old 05-04-2015, 11:37 AM
Bobs-00-SS's Avatar
Tires are MT ET streets mounted on 16'' WS6 wheels. Skinnies up front
Old 05-04-2015, 08:57 PM
et streets and 60 footing @1.98 with a 115 trap ... yes it surely has 11's in it , my 2 bolt on cars went 12.1 on a 112 trap (1.7x 60 foots on et streets fyi) and 11.9 on a 111 trap you just need to fix your 60 foot like 98cayenneTA is saying.
what pressure did you have the et streets at ? I had to pull my front sway bar , toss my jack and tool box in the trunkwell and air down to 14psi due to bad track to find those 1.7's.
I think the a4/4000 stall swap alone will make it way easier for you to get there , 6 speeds on dr's is tough they really prefer a slick both for traction and to avoid parts breakage.
Old 05-04-2015, 09:14 PM
s_desantis's Avatar
High 10's I'd say
Old 06-22-2015, 08:00 AM
z28SSilvest's Avatar
Originally Posted by s_desantis
High 10's I'd say
A bit optimistic but can't say it can't be done... with a 1.0 60 foot
Old 06-22-2015, 08:10 AM
HCI2000SS's Avatar
Umm high 10's is not going to happen here lol
Quick Reply: Think I will be in the 11's?
