11 Second Club Snake eyes are a good thing
Cam Only WS6 11.6 @ 116
Old 11-28-2015, 07:02 PM
spicebird98's Avatar
Default Cam Only WS6 11.6 @ 116
Took the trans am for a Test N Tune today to see where its at. Havent ran the car since owning it so wanted to try a few things out. Car is a 99 ws6 automatic, cam only. Basic rundown: stock bottom end, 237/242 ~.600 112 similar to MS3, lid, ls6 intake mani, pacesetters, shitty off road y pipe, magnaflow catback, RPM built 4L60E, yank ss3600 stall, 3.73's, weld rts fronts w/ heavy mickey thompson sportsman radials, zr1 rears w/ hoosier DR's 275/40 set at 20 psi. Full weight car with 12" sub, 2 amps, empty 10lb nitrous bottle so probably a little over weight. Temps were mid 60's. Tune could use some work, it likes to search for an idle from time to time. Shifting at 6600.
R/T .008
60' 1.64
330 4.79
1/8 7.44
MPH 94.49
1000 9.74
1/4 11.674
MPH 116.62
Not too bad IMO, could pick up with a few minor adjustments. Definitely would like a 4000-4200 stall, crosses the traps at 6000 rpm. Have to check what the DA was, pretty muggy out all day
Old 11-28-2015, 07:03 PM
madmike9396's Avatar
Awesome run. Mine and your car runs almost identical
Old 11-28-2015, 07:06 PM
thanks man, whats your setup?
Old 11-28-2015, 07:42 PM
first time out today
02 z28
799 heads
FMS F14 cam
FTI 4K hard hit stall
456 gears
1.70 60'
ran 7.3@94.53
11.54@117.17
Old 11-28-2015, 08:17 PM
HCI2000SS's Avatar
That's actually pretty good for your setup and being full weight
Old 11-29-2015, 06:56 PM
mjs1012's Avatar
Nice run your car and mine run very similar but I have less weight, a smaller cam and only shift at like 6200. Get that 4k+ stall and see what it'll really do. Do you have a ram air kit ie. ssra/chris1313?
Old 11-29-2015, 11:08 PM
No ram air kit yet. Just getting air from the factory ram air hood and high rise box. Could definitely optimize with a SSRA or chrs1313 setup, I've had both before and worked great. Actually forgot to pull the front sway bar too so might've helped the 60 on that
Quick Reply: Cam Only WS6 11.6 @ 116
