Terrible setup but made it into the 11s
So here's the thing have a bolt on ls1 with a tci ssf 3500 stall converter went a 12.02 @112 with a 1.63 60" hooked up the giggle 100shot jetting on a Nos plate juice and had instant traction issues so I left on motor cut the spray on about 30ft out bottle was at 750psi so I was dead rich all the way down ran a 11.41 @119 with a 1.63 60" upping the jets to a 150 shot hooked up a bottle heater to get the bottle pressure up removing front swaybar and putting comp engineering 3 way adjustables out back set on 50/50 and installing a NX maximizer 4 to progress the nitrous out of the hole shooting for 10s next
Mine hook best at 22 pounds. Most of the guys I know who run them stay in the 18-22 range. Start at 22 and work down if needed. Usually the first burn out should be a long burn and then you wont need much unless its unseasonably cold out.
Almost pulling them front wheels!! Almost
what rpm are you leaving at? Are they dead hooking for you?
