11 Second Club Snake eyes are a good thing
11.14 @ 122.98
Old 08-25-2004, 11:36 PM
critter's Avatar
Default 11.07 @ 122.98
Y2K Z28 stripper
M6
Moser 12 bolt - 4.11
all the boltons
PP LQ9 heads
232 Comp cam
78 mm Fast w/ Bauer TB
stock bottom end w/ 20% ring leakage
3350# race weight
Edit:
Didn't make the 10s. Best was a couple 11.07s, but I did get a 6.96 @ 100 eighth backed up with a 7.01. Time for rings ...
Old 08-26-2004, 08:04 AM
scottywheels's Avatar
nice mph what are you dyno numbers?
Old 08-26-2004, 05:41 PM
critter's Avatar
I don't know It has never been on a dyno. I'd guess in the 400 - 425 range.
Old 08-26-2004, 08:46 PM
CamaroCain's Avatar
very nice times, can you post the whole time slip? What wheel/tire combo are you running?
Old 08-26-2004, 11:26 PM
critter's Avatar
Thanks, and sure. (finding log book ... )
RT 0.306
60' 1.596
1/8 7.131 @ 97.66
1/4 11.14 @ 122.98
7.5 psi
6400 launch
Actually, I wish mine ran as good as yours I am trying to get the 60' down - putting 5.13 gears in and plan to launch at lower RPM and see if I can get rid of the spin. Maybe I can transfer to the 10 sec club after Labor Day ...
10" x 28" x 15" Hoosier slicks on 8" Weld ProStars in back, MT skinnies on narrow Weld ProStars in front.
Old 08-27-2004, 12:45 AM
LittleBoyBlu99's Avatar
How much Lift" does that 232 cam have?
Old 08-27-2004, 09:03 AM
critter's Avatar
It has the 3726 lobes on the intake and 3719 on the exhaust, but the Pro Mag rockers give it .6125"/.5915" specs. Seems to work fairly well
Old 10-10-2004, 08:36 PM
critter's Avatar
Getting closer - 11.07 but the MPH is down to 121. Prolly the 5.13s I put in to try to get it to 60 ft. I think the et improvement is due to the 60 ft dropping 0.08 sec to 1.517 and 1.525. The two changes that could account for this improvement is changing the shocks to four clicks from one and just hazing the Hoosiers. My brother is used to 1/8 mile burnouts with his old altered, so he had me heating the tires too much. Anyway, not too bad for an engine with 20% leakage and an M6.
Time is running out - we only have one or two weekends left and I mashed the front end up loading it on the trailer - I may not get 10's before the winter rebuild.
Quick Reply: 11.14 @ 122.98
