anyone in the 11's with full bolt-ons and TSP 233/239
i'm just curious who has made it with a setup similar to me. i'm finally getting to go to the track on Saturdayand wondering what to expect. my car is a 98 Z28 full bolt ons, ssf3500, 3.73's, TSP 233/239, TSP tune and my race weight will be around 3600 lbs. best run last year with just a lid, catback and converter was a 12.93 @105 on street tires with a 1.759 60'. do i have a good shot at making it in here.
suspension is all stock. believe it or not i have no wheel hop issues or anything like that. i feel that it works great imo and really see no reason to mess with it and possibly screw it all up and have the car never hook right. only thing really done is i took the front swaybar and its brackets off.
1.79 is not all that great. You'll need to get it down in the 1.5x range. Get some tires, then do the suspension. No chance of making it worse. Reloc brackets are a good start, then add on some good lower control arms. Horse power is good, but you gotta get the 60 ft down.
Ed
Ed
Ed
Ed
I understand where you are coming from, no sweat.
I was just giving my opinion, which my be different than everyone else
So here is my thoughts:
- If you ran the 12.93 stock internal on a 1.75 that is OK, but not that great. Drag racing is an acceleration test. One of the key indicators is your 60 foot time. I have never focused on ET, I knew if I got the 60 down it would fall in place. Every tenth on the 60 translates to at least 2 tenths on the ET, so if you get the 60 down in the 1.5x range your 12.93 would be at least 12.5, if not better. Wheelp hop is not what I am concerned with, I want to see the 60 drop.
- Your stock suspension might have been OK for a 1.75, but to do better than low 1.6's you are better with upgrades.
- The cam should really help your MPH. 105 is not that good either, if all stays the same I doubt you'll see 11's saturday. If you can hook it and get the 60 better you might see real low 12's.
- Boxing your LCA's might work OK, I've never heard of anyone doing it, BMR's are pretty cheap. The stock Torque arm can handle well into the 11's, I know of cars in the 10's on one. The reloc brackets change the length of the lever on your rear end and will help it bite better. Guys have gained .1 in the 60'd from them and they are cheap. QA1 shocks and front drag springs allow your weight to transfer to the rear faster and also increase traction and bite. They are not cheap though.
- I understand that building a fast car is not cheap, I am right there with you, doing it on a limited budget. Every car part I buy takes something away from my family. I would say doing your suspension will cost around $1000 and be good for .5 - .7.
-My car dyno'd 346, I don't have all the bolt ons, it ran 11.73 with all the seats in, but that was in great air. Right now I run 11.9x with a 1.53 60.
Good luck!
Good luck!
sorry i never responded about what i ran. i actually forgot about this post. i'll start by saying track conditions were horrible, no track prep at all, it was about 90 degrees with about 90% humidity. second, i was stubborn and had to try on my street tires instead of my DRs. i still managed to run 12.51 at 114.73 mph with a 2.0 60'. i was happy with the speed though. we're going to rent another track in late august and try again, this time on the DRs. if i can get my 60' down to 1.7's like they were last year, the car should go high 11's.
I have almost the same mods as you, see sig, and I went 11.90@115. That was with drag radials and I had to launch at 1400 rpm. Cut a 1.72 60' on a stock suspension. I did disconnect the front sway bar though. I did run a string of 12.03s and then I put on the shorty belt to bypass the power steering. I have a stock crank pulley so I used a 56" belt. Good luck.
WOW!!!! Holy sh*t, someone on LS1tech from my area. I had the Red T/A at Beaver for the track rental on the 4th of June. I take it you were the White Z. You should have no problem hitting 11's with that setup plus suspension mods. I have the Spohn torque arm that mounts on the chassis where the G-load brace goes. Seems to work well but not with street tires. I believe my 60 dropping from 2.23 to 2.0's came from the 4.11 gears. I have a set of BMR relocation brackets to fit the stock 10 bolt. I can't use them on the Moser. They don't fit. What tune are you using? I'm still on stock tune with bolt ons and have been considering a mail order now that I installed the LS6 intake. I want to get as far down in the 12's as I can full weight before a cam swap though.
i'm bringing this one back from the dead. went to the tracklast friday and best i got was a 12.38. it was real hot and humid that day. i'm gonna go back in september with a few tweaks and some suspension work and run in good (hopefully) air. i'm pretty determined to go 11s on this setup.
dont feel bad i have all this and i went 12.4 with mt et streets burn out were to short , i launch at 5500 rpms.... need a new drive shaft should be here tomorow and im back to the track for 11s
