This is what it takes on the dark side - LS1TECH
11 Second Club Snake eyes are a good thing
Thread Tools Search this Thread
Old 06-12-2005, 08:53 PM   #1
Default This is what it takes on the dark side
89 Mustang 351W, stock weight with full interior
Edelbrock RPM intake and RPM heads 75mm TB
77mm MAS
BBK long tubes with 1 3/4 primaries
Motorsport A351 flat tappet cam: 236-244 duration at .5
max lift 5.19-5.28
5psd and 4.10's in stock rearend (a copied Chevy 12 bolt)
Stock crank, rods, pistons, producing 8.8 to 1 compression with chosen heads
Exhaust cut outs (worth about .06)
short belt
home made ram air protruding through opening for headlight (it helps)
11.69 at 117 on ET Streets with a 1.55 60ft
Do I qualify? This might be interesting as an anecdote
You have a great site -set up for enthusiasts who use their cars!
Okay here's the whole thing (I'd like to be a member):
60 ft 1.55
330 4.76
1/8 mile 7.47
1/8 mph 91.30
1000 9.78
1/4 11.69
mph 117.03
esoteric is offline   Reply With Quote
Old 06-14-2005, 02:16 AM   #2
b00sted's Avatar
You're in the 11s on the motor with 8.8:1 compression?
b00sted is offline   Reply With Quote
Old 06-14-2005, 11:43 AM   #3
Quote:
Yes. Stock compression on a 351 is 8.1 with 69cc heads. The Edelbrock RPMs have 60cc chambers = 8.8
Old 06-14-2005, 12:42 PM   #4
Tranzor's Avatar
That's a wicked fast car you got there, bud... saw it first hand during the races. If I could get my 60' down a bit (switching from 4.11s to 4.30s in the near future) you and I could have a hell of a race...
Tranzor is offline   Reply With Quote
Old 06-14-2005, 03:26 PM   #5
Quote:
Thanks.
Please say hello at the track. I am interested in seeing your car more closely. It would be informative if you could explain your list of mods and I could see the application in front of me. It looks as though our cars have a near identical power-to-weight ratio.
Could you get a shorter tire rather than change gear ratios? It might be cheaper, and if it doesn't help, you have more options.
Old 06-14-2005, 03:49 PM   #6
Tranzor's Avatar
Quote:
Originally Posted by esoteric
Thanks.
Will do... my CCC number is T41 (NW F-body) if you want to look me up at the next CCCA race. My race weight is probably around 3800 or so with me in the car if I do my math correctly.
As for a shorter tire, I'm on 26" ET Streets right now, can't really go with a much shorter tire than that... and the gear set is pretty cheap, can be had for around $200 for a new set. Gears seems to be the easiest and cheapest way to overcome the slight bog I have about 30' out after the launch... seems to be a flat spot right there.
Old 06-15-2005, 10:22 AM   #7
What about the cost of gear installation? Do you do that yourself? I do almost everything myself, but not that job.
Old 06-15-2005, 11:44 AM   #8
Tranzor's Avatar
No, I don't do rear diff or tranny work myself... I have a guy who does it dirt cheap for me though. His only stipulation is that I keep racing... so I'll keep driving if he keeps the drivetrain in good working order.
Old 06-23-2005, 10:10 PM   #9
77mm MAS
max lift 5.19-5.28
short belt
60 ft 1.55
330 4.76
1/8 mile 7.47
1/8 mph 91.30
1000 9.78
1/4 11.69
mph 117.03
I guess I don't qualify...
Old 06-24-2005, 12:19 AM   #10
hpjunky98's Avatar
make him a 11 sec member!
hpjunky98 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Fastest LT1's on LS1Tech.com gregrob LT1-LT4 Modifications 434 09-24-2016 10:45 PM
25 Fastest LSX's in Ohio koolrayz Midwestern Members 162 05-12-2015 05:30 PM
TTI 60 trim track results cbr600rx7 Forced Induction 2 05-11-2009 10:50 PM
Steele Saturday tlo94ta Southern Members 10 02-03-2009 12:07 AM
First Nitrous Runs... Damn That Was Fun!!!! 02bluess Drag Racing Results 22 09-26-2004 09:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
