11 Second Club Snake eyes are a good thing
488 rwhp/430 ft./lbs. stock bottom end 346
Old 09-09-2006, 09:56 AM
Weekend Racer's Avatar
Default 488 rwhp/430 ft./lbs. stock bottom end 346
I will be testing my new set up 02 SS M6 in commerce/GA on 09/22/2006. Before numbers with 360 hp/382 ft./lbs. torque was 12.78 @ 111 mph on stock 10-bolt 4.10 gear full weight (jack and spare in the car). This time was achieved shifting at 5900 rpm's and 1.92 60 ft. using sissy launch. Any recommendations to achieve better times and hopefully getting in here would be appreciated. I don't want to break the 10-bolt. I should be in the 11's easy. 12.78 was at 7:00 p.m in May w/90+ degree weather.
Old 09-12-2006, 01:44 PM
transam1998's Avatar
I broke my 10 bolt on the second pass with Nittos and 355 rwhp. Ran 12.45 the first run. Snapped and axle on the starting line on my second run.
Old 09-14-2006, 07:42 AM
396LT1's Avatar
You should have no problem 11's on your 10 bolt. I currently running 11.6-11.8 on a stock 10 bolt with 3.23s.
Old 09-20-2006, 09:29 AM
02 Camaro SS's Avatar
^ An A4 can get away with it. Chances are the M6 will explode the rear with a decent launch.
Old 09-20-2006, 10:00 AM
Ron@Vengeance's Avatar
Dont worry about the rear Joe... If it breaks, call me..... Ill have the trailer on standby!!!
Old 09-20-2006, 01:10 PM
jj_z28's Avatar
odds are w/ the m6, u break if u hook at all. Just go easy off the line. I broke on my 2nd pass w/ 430 rwhp on nitto's. I broke the driverside axle shaft. Good luck.
Old 09-20-2006, 02:34 PM
Yup, driver side axle here as well, snapped right at the splines. I launched, hooked, heard a clunk and the car pulled to the left, then I had some rear steering
Old 09-21-2006, 02:49 PM
jj_z28's Avatar
Sounds fun. Mine broke at the same spot. My car just rolled about 8 ft. and wouldn't move under its own power. Well, I guess it would catch every so often and move a little. The stock limited slip was shot so I'm surprised it broke at all.
I love this pic.
Old 09-28-2006, 11:31 AM
stealth71's Avatar
What mods are on the motor to make 488/430? Heads, cam specs....
Old 09-28-2006, 12:03 PM
Demonicbird00's Avatar
i as able to reach a 12.0 @117 w/ my 10 bolt and 3.42s and stock clutch. just slip the clutch from 4500 and youll hit a 1.7/8 60. and easily get your 11 sec pass
-brandon
Old 09-28-2006, 12:27 PM
I love this pic.
Looking at that pic gives me Deja vu
Old 09-30-2006, 09:54 PM
RickC5's Avatar
ouch that looks painful!
Quick Reply: 488 rwhp/430 ft./lbs. stock bottom end 346
