11 Second Club Snake eyes are a good thing
11`'s with 2.73 gears?
Old 09-14-2006, 05:55 AM
TXZ28LS1's Avatar
Default 11`'s with 2.73 gears?
i was wondering if any of my A4 guys are dippin in the 11's with 2.73 gears? if so, what is yur setup?
Old 09-14-2006, 06:46 AM
GM Muscle's Avatar
No problem at all. With bolt ons a 150 shot I was running 11.3-11.4 in full street trim. Went high 10.90s after I did some weight reduction and suspension mods.
If you want to do it N/A, make sure you do your homework when it comes to converter selection.
Old 09-14-2006, 05:01 PM
TXZ28LS1's Avatar
damn GM muscle thats impressive. what were yur numbers NA? what cam and stall are you running?
Old 09-14-2006, 06:15 PM
GM Muscle's Avatar
I've never made an N/A pass with the car. I imagine it would run around 11.7-11.9 with the nitrous tune. I run an MS3 cam and the converter is a Midwest 3500 with a 2.5 str. N/A out of the hole the converter really doesn't hit hard enough, I would like a 3.0 str. I imagine if your looking to stay N/A only you'd want to look into 4K+ stalls.
Old 09-17-2006, 08:24 AM
sleeperstyle's Avatar
i studied gmmuscle's setup (although pretty simple) and came out with a pretty good running SI 2.73 car .
n/a it usually runs 12.1-12.3 @ 109-110. in good air it went 12.0 but it really doesn't launch hard enough to get an 11 on motor. maybe with a bigger stall it would've- im changing the setup over the winter though so guess i'll never know.
3500 raceweight, sfc's, panhard bar, some weight off of the front end (battery/swaybar/support/ac). otherwise stock suspension. no skinnies or anything crazy. check the vid
Quick Reply: 11`'s with 2.73 gears?
