11 Second Club Snake eyes are a good thing
11.68 @ 115mph
Old 09-27-2007, 06:02 PM
99NavyTA's Avatar
Default 11.68 @ 115mph
New best time
Car has SS4000 Torque converter, AFR HEads, and G5X3 cam...
car needs gears and suspension
.3901 Reaction
1.6705 60'
4.7690 330ft
7.4448 1/8th mile
84.78 mph
9.7223 1000'
104.99 mph
11.6836 1/4 mile
115.09 mph
Old 09-28-2007, 01:27 AM
Bill'sWS6's Avatar
Originally Posted by 99NavyTA
New best time
.3901 Reaction
1.6705 60'
4.7690 330ft
7.4448 1/8th mile
84.78 mph
9.7223 1000'
104.99 mph
11.6836 1/4 mile
115.09 mph
Great Run!
Wow, your time is pretty damm close to mine (see below). What kind of weather were you running in? What is your car shifting at?
60' = 1.54
330 = 4.69
1/8 ET = 7.38
1/8 MPH = 91.27
1000' = 9.72
1000 MPH = 106.66
1/4 = 11.68
1/4 MPH = 113.94
Old 09-29-2007, 01:17 PM
99NavyTA's Avatar
it was 72 degrees and I was shifting at 7000 RPM
Old 09-29-2007, 01:20 PM
99NavyTA's Avatar
My car only has 10.3:1 compression ratio
It put down 385HP with stock exhaust and a 2.6 STR converter
Old 09-29-2007, 08:34 PM
gillbot's Avatar
Close to mine with a PT4000 converter:
1.6229 - 60'
4.8031 - 330'
6.9690 - 594'
7.4538 - 1/8th
92.82 - 1/8th MPH
11.6949 - 1/4
118.74 - 1/4 MPH
Old 09-30-2007, 01:22 AM
98REDZ's Avatar
damn good MPH though gillbot,...... 99navyTA what tire are you on? for all you guys anyways,...i notice you are H/C,...stock suspension I assume,....cuttin 1.67,... Im cam only, stock suspension and hittin 1.56
Old 09-30-2007, 02:14 AM
99NavyTA's Avatar
I am running a MT ET Street Radial
255-50-16 on a firebird wheel.. And yes that was Stock suspension and stock 3.23 gears
Old 09-30-2007, 08:31 AM
gillbot's Avatar
I don't have heads, mine are 100% stock. For suspension I have Slot Car Products lower control arms and a Trackbird Panhard Bar. The Torque Arm is stock. I use Mikey Thompson drag radials on stock 16" camaro wheels.
Old 09-30-2007, 10:32 AM
98REDZ's Avatar
Alright then are you guys spinning a little im guessing? I'm on a ET Drag and have a Fuddle 4000 w/ a 2.5STR
Old 09-30-2007, 01:18 PM
gillbot's Avatar
My best 60 so far is a 1.62. I think with a little better track prep and tweaking of the tire pressure, I could get in to the 1.5x range.
Old 09-30-2007, 08:13 PM
2000_SS's Avatar
curt?
Old 10-01-2007, 12:03 AM
99NavyTA's Avatar
Ben!!
Old 10-01-2007, 12:11 AM
98REDZ's Avatar
Hmm, your cars got some things mine doesn't im guessin, im also on stock heads, put down 355hp,...11.74@114/1.56 Your MPH is quite a bit higher than mine.
Old 10-03-2007, 12:04 AM
its turbo time's Avatar
are your mac headers really crappy? i've got some and don't have anything to compare to
Old 10-04-2007, 12:34 AM
SLP4CamaroSS's Avatar
get a wideband so i can tune your wot some more and youll see low 11 high 10s
Old 10-04-2007, 07:04 PM
gillbot's Avatar
No idea, my mods are posted on here somewhere. I'll try and find the link.
Here it is: https://ls1tech.com/forums/dynamometer-results-comparisons/476349-tr230-224-a4-dyno.html
Most of it probably has to do with the powerband of the cam.
No, they work fine. It's just a fun "poke" at all the threads that talk about how bad MAC headers are when 90%+ of the people here are just reciting rumor.
Old 10-04-2007, 09:36 PM
^^ i see, after i saw that on in your sig i searched and found guys who went from mac's to LT and saw absolutely no gains....sorry for the hijack
Old 10-05-2007, 12:30 PM
gillbot's Avatar
No problem. I still say if you have nothing then you should get LT's but at the prices you can get used macs for they are one hell of a bargain at times!
Old 10-11-2007, 09:34 PM
gillbot's Avatar
Old 10-19-2007, 08:28 PM
bjamick's Avatar
Shouldn't a H/C car be running better than 11.6?? Something seems off?
Quick Reply: 11.68 @ 115mph
