11 Second Club Snake eyes are a good thing
What gears are u 11 sec guys running?
Old 02-06-2008, 07:22 PM
red_ryderSS's Avatar
Default What gears are u 11 sec guys running?
I have a 9 inch I'm ordering after tax returns, with the mods in my sig and power level, I'm debating on going 3.90 or 4.10s. I'd like to here what power levels, gear ratio and height of tire u guys are running. But any info helps right now. Thanks guys
Old 02-06-2008, 08:15 PM
SSmoken's Avatar
well i have a stock 10 bolt with 3:73's with a 255/50/16 bfg's.
Old 02-06-2008, 08:17 PM
j99fbody's Avatar
Stock 10 bolt with 373s, 26X10.50 MT ET drags
Old 02-06-2008, 09:29 PM
BOLO's Avatar
Stock 10 bolt w/4.10 gear/ MT325/50-15 drag radials on 150 shot.
Old 02-06-2008, 09:46 PM
Any m6 guys?
Old 02-06-2008, 10:20 PM
'Trust''s Avatar
3.23's, A4 here.
Old 02-06-2008, 10:51 PM
Tech Fanatic
yellowbird1232's Avatar
M6 w/4.10's MS4 NX 125 wet shot = 11.03 @128
Old 02-06-2008, 10:52 PM
Tech Fanatic
Oh yeah it has a strange 12 bolt and BMR rear suspension.
Old 02-06-2008, 11:09 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
My old Z28 went 11s with 2.73s
The CETA went 11.15 @ 129 with 3.42s
Old 02-07-2008, 09:13 AM
ViperJ's Avatar
Stock rearend with 4.10's for me
Old 02-07-2008, 11:33 AM
Any other na guys. I plan on going all motor, no one uses 3.90's?
Old 02-07-2008, 02:11 PM
Unstang's Avatar
Get 4.10s.
FWIW, I run 3.73s in my A4 car.
Old 02-07-2008, 03:15 PM
Greaseymec's Avatar
3.89s on a 9" here. Old setup in the sig. Car is torn apart at the moment. The car did it on a 27" QTPs cutting 1.59 60' times consistantly. 11.88 all motor shifting at 6300. RWHP around 370.
Mec
Old 02-07-2008, 04:55 PM
bad6as's Avatar
it depends on what you want from the car and how many rpm you spin, tire size any future mods?
Old 02-07-2008, 05:58 PM
'Trust''s Avatar
I haven't heard of a 3.90 gear for a 10 bolt, do you know of any?
Old 02-07-2008, 06:48 PM
I'm not thinkin of gears for the ten bolt, its for the 9 inch. As far as future mods, either a 150 shot or a procharger down the road. My biggest concern is having to shift into fifth at the end of the quarter mile. Thus the debate between 4.10 and 3.90
Old 02-07-2008, 06:49 PM
bad6as's Avatar
do you plan on using a 26" tire? whats your revlimit
Old 02-07-2008, 07:25 PM
My rev limt is 6300 I plan on runnin a 315 17 dr for the time being. But the future I'll run some prostars and haven't made up my mind whether to run a 26 or 28 inch tire.
Old 02-07-2008, 07:48 PM
bad6as's Avatar
well with a 26" tire 6300rpms in 4th you can go 123 with 3.90
26" tire 6300 rpm 4th 4.10 117mph
28" tire 6300 rpm 4th 4.10 128
28" tire 6300 rpm 4th 3.90 135
Old 02-07-2008, 07:51 PM
bad6as's Avatar
fyi i have bolt ons, and a toquer v.2 cam with 3.90s with a 6600rpm revlimit. i plan on using a 150 dry shot with a 26" m/t et street i can go 131 in 4th
imo i say you get 3.90 and use the 26" tire. you can bump up the revlimiter a few and i think its 2mph for 100 rpm
Quick Reply: What gears are u 11 sec guys running?
