ELEVENS Cheap!!
ELEVENS Cheap!!
1998 SS A4 fuel weight, pacesetters, drag radials, lid, and .057 wet shot.
11.72 @119 1.72 60. Opening night at KID track was SLICK. Wife was mad does not like spray Car has more, because 1-2 shift did not like the spray.
Stock converter and stock 3.23 gears. Nitrous express shark nozzle. 1-2 was lazy. Only made one pass on spray because it was so late. Car was running 13.2x's all motor. No weight removed, stock rear. No tune yet. Wide band was 12.0-12.4 through pass. I had fuel jet 2 sizes short.
wow thats around what I want the z to be running on spray only problem is the gf dont like the spray either, because she says its not ment to be a race car,I say just cause it has spray does not make it a race car.
what size drag radials? and what 60'were you cutting on motor
No guys it is Her car. I have an 406 powered 85 Camaro. I bought it for her to drive. But because I bought it, I figured a little spray was in order! The real hold up for her is not trashing a very very clean low mile SS. Also if I cam it and converter it, then work the trans, I have no doubt it would be in the tens if the rear would hold. So she is "I AM NOT LETING YOU PUT A CAGE I THAT CAR!"
I guess thats life! To easy to make an LS car fast!
