12 Second Club In the 12s yet? Come inside!
12.03 @ 114 mph.
Old 10-05-2010, 01:55 PM
veloxetmortifer's Avatar
Default 12.03 @ 114 mph.
I posted this again because there were some problems with the link I posted.
My car that took 5 years to build to this point. She does 12.03 @ 114 mph on street tires and 100 Shot of nitrous. My previous car was an 82' Camaro V6 2.8L, so, yes, I love Camaros. Here's what's in her so far...
1. 5.7L V8
2. LS2 Heads with Titanium vavle springs
3. Thunder Racing cam (224/224 .563/.563 112LSA)
4. Comp Cam timing chain
5. Manley push rods
6. Melling HV oil pump
7. NGK Tr6 Spark plugs
8. Metco Motorsports Billet fuel rain
9. 42# Injectors from EFI Componenets
10. 100 Wet shot nitrous kit from Nitrous Outlet w/ 10lb bottle and automatic bottle heater.
11. SLP Cold air intake
12. High Flow MAF
13. 72mm Throttle Body
14. 3000 RPM Stall from TCI
15. 1 3/4" Long tube headers, 3" y Pipe and 3" E-Cut out all from QTP.
16. A GMMG Chambered Muffler
17. 12 Bolt Moser w/ 3.73 gears and an Eaton Posi
18. Glow Shift guages (Nitrou Press, Tranny Temp and Fuel Press)
Dyno Specs:
Engine: 384 hp@ 5600 rpm and 391 ft/lbs of torque
W/ Nitrous: 475hp @5479 rpm and 661 ft/lbs of torque
http://www.youtube.com/watch?v=GIHFTOiDam0
Old 10-05-2010, 02:00 PM
01SS99red's Avatar
The 12.03 is that on motor or on the juice?
Old 10-05-2010, 09:06 PM
It's on juice.
Old 10-06-2010, 12:20 AM
X-ray's Avatar
What was your 60'?
Old 10-06-2010, 12:27 AM
1.900. I was told I need drag tires.
Old 10-06-2010, 12:37 AM
X-ray's Avatar
Yeah you do, but 1.9 60' actually seems pretty good for street tires. I've only dragged a couple times but the best I did on street tires was a 2.2 60' (13.08 @ 110mph)
Old 10-06-2010, 01:14 AM
My next items are a line lock and drag tires. Hopefully those i'll get my times down even lower.
Old 10-06-2010, 01:52 AM
Zmg00camaross's Avatar
Yeah some tires would help out. what track to you run at and what was the weather like.
Old 10-06-2010, 09:44 AM
I run at Infineon Raceway. It was Sunny that day. A couple of clouds. The barometer was 29.76.
Old 10-06-2010, 10:42 AM
buzz12586's Avatar
Any idea what the DA was when you ran? The MPH is low for your car on motor, let alone on spray.
Old 10-06-2010, 10:56 AM
I don't. Sorry. The only info I have on my slip id the barometric pressure for that day. How would I go about acquiring the DA?
Old 10-06-2010, 10:59 AM
buzz12586's Avatar
http://www.dragtimes.com/da-density-...calculator.php
Also do you know what the car weighs?
Old 10-06-2010, 01:16 PM
Thanks for the link. I inputed the info...
Density Altitude: 1751 feet
Relative Density: 94.98 %
The calc said I should be doing 11.892 @ 115.831 MPH
The weight is around around 3600 lbs.
Old 10-06-2010, 02:01 PM
buzz12586's Avatar
Yea that's a pretty good DA. If the car dynoed 380 on motor and 480 on spray it should trap in the 117-118 range on motor and 127-128 on spray.
Old 10-06-2010, 06:01 PM
That would be freakin sweet. I wish I could trap those speeds. I'll post slips when I get the line lock and the tires.
Old 10-09-2010, 12:23 PM
zracer323's Avatar
Are you sure the nitrous is activating? That trap speed seems pretty close to what you should be on motor? My car traps over 118 on a 125 shot on stock heads/cam/intake.
Old 10-10-2010, 07:33 PM
I'll have to check the solenoids. I brought down the progressive controller rpm to 1500 and hit the WOT switch. The fuel solenoid sprayed but I didn't check the jiuce. I guess I'll be wrenching this week. Thanks for all the info. Hopefully I can bring down my times.
Old 10-12-2010, 08:43 PM
philsblwnz28's Avatar
Line lock and DR's FTW.....Get em
Old 10-13-2010, 09:35 PM
its turbo time's Avatar
+1 on the trap speeds being off, i trapped 117 on stock internals with a 100 shot...you should be well into the 11's with that setup also
Quick Reply: 12.03 @ 114 mph.
