12.58 @ 114.98
12.58 @ 114.98
I took my 2002 camaro z28 to the track 1-21-11 for the first time and had major traction issues but still managed to run a 12.58. i'll be back up there next friday to try and lower my time.
bought the car as is. I can't remember the size of the cam
cam, FLP long tubes, and comp 918 springs.
eibach sport line springs
umi adj lca
umi adj panhard and panhard relocation bar
umi tunnel mount adj tq arm
new poly tranny mount bushing, and prolly about to do poly motor mounts
pro 5.0 shifter
umi adj lca
pro 5.0 shifter
Yeah i know i should be up there but it was 28 degrees and i didn't take out enough air pressure. I have the nitto NTO5r drag radials but if I don't lower my 60 ft friday i am going to have to go with some mickey's
a guy at the track kept on recommending them to me so I think ima go to a local M/T dealer first week of feburary. but first ima drop the tire pressure to 15 friday. I was at 20. if it doesn't budge then ima go with the mickey's
I put around 60-100 passes on a "rebuilt" olds 10 bolt rearend I've had since 05. I planned to do gears this year anyway lol
yeah my girl says that these things are just toys that happen to cost thousands of dollars lol
I bought the car 1-4-11 and they came with the car. the previous owner had put these on maybe 4 months back and the car sat in his driveway most of the time. I bought it off of a friend, but Ima give them one more go friday then im gonna have to get some mickey's if they still don't grab. it was extremely cold so that may play a small part in it but i doubt it. You can hear that I even scretch going into second slightly.
Restricted User
