What should I run
What should I run
Last time at the track I ran a 12.97@108 since then I installed a bbk ssi intake and will have a s60 with 4.11s in it with et streets what times should I expect I got only a handful off passes under my belt. Should I be mid 12s or higher lower assuming I can get my 60s down Im shooting for 11s but ima need a cam for that.
Finally got it to the track last night fastest time was a 13.066&107 da was like 2200 does that sound right I was running a 345/30/17 tire was really tall and I had to really leave hard so I wouldn't bog I just thought I could get a better time then that
Went 12.65 last weekend in my 2001 Trans Am, mods are lid, longtubes, catless Y-pipe, borla catback closed off, Ls6 intake factory built 4L60e with a Yank SS 3600 stall,stock 2.73 gears on nitto 555r Drag Radi's.
12.65 with a 1.86 60ft at 108mph. next is cam and spring thinking along the lines of 228/230 588 592 on a 112lsa.
going to hit the strip again this weekend and see what she will do. da is going to be horrible but im running a 275 et street instead of the 345s hoping to atleast get mid 12s out of this thing
