New pb 12.57@106.xx
New pb 12.57@106.xx
Ran this a while back I've had multiple 60' in the 1.77-1.79 range so I know I can improve on this some trying to get down to a 11.99 da was somewhere between 1400-1650
98' z28. 100% Stock motor w/159xxx w/ Lt headers, 3" ory "shity kind of merge" bullet and turn down, diy p&p on the maf, udp, lid, k&n filter that I've cleaned and don't oil, 3.42's, northtexasconverters 3600"that's on the tight side " stall, trans built by me, tuned by me with HPT lol that rhymes. 275/40/17 Mt street ets on stock ss wheels. Qa1 single adj coilovers front n single adj shock rear
Only weight out of it is the spare n jack and no front sway bar, Im 150 wet lol
I have always felt like the back half was on the slow side.
I'm new to tuning, my prior best was 12.63@ 105.66 same mods but I hadn't rebuilt the trans yet or tuned it. The trans was in perfectly good shape but I had torn up the converter at the track, so I tore the trans down to check it out. My first 4l60e build
you say your new to tuning , are you using a wideband ?
if not get the fueling in line and you can likely add some timing and get that 2nd half up to 22/23mph gain and get it trapping in the 110 range overall which is where I would expect to see those mods trapping , add that to your decent 60 foots and you should be 12.3 ish. Then add a ram air and ls6 intake and you will be knocking on the door of 11's.
So why is my mph so low when others do things like this so why can I not run 109-112 fastest I've ever ran was 107.xx
I don't think its the track equpitment becuz hp tuners shows same mph whenever the tps stops showing 100% so I'm threw the traps and they are away about spot on with the log
well it seems that I'm getting some retard from 3/2 downshift that hangs around threw the entire pull and from the limiter that I just barely blip on the 2/3.
so I'm gonna make some adj to shift points or limiter/both see which works better and see what happens weekend after this one when the track opens for the year
