Not the best outing
Not the best outing
Went to royal purple two weeks ago and had a tough time. First of all I had the metal part of a broken valve seal in my Drain plug and other parts in my oil filter. Brought down my oil pressure to 20 PSI at idle (I have a melling high volume and it never drops below 40). My pressure pegged out at like 50 instead of 80 PSI+. After the track day I did my oil change and replaced valve seals, and runs sooooo much better...
That being said I ran 3 different times all the same 12.8 ET. I was trapping 116.9 and I am just beside myself because I was expecting so much more! I will post some vids soon. I was cutting 2.2-2.3 60' on street tires. I am wondering if my car will hit the 11's :/
That race where I got beat by a car with that FBO lightened E85 coyote, I had the same issue with my oil pressure as I did at the track. I need a rematch. I wonder If It'd be even or if I'd pull.
Glad to see you got the oil and valve seals right. If you're going for 11s at the track it looks like you'll need about a 1.85ish 60'. A tire/dr would help you quite a bit. IMO a tire/dr, chris1313 ram air w/AC, FTP 98mm lid, truck 85mm MAF, & home ported TB would be next on my list and should get you to the times you want. Obviously a FAST would be awesome but its just about how much you want to put in it like anything else lol
I think the torque arm relocation and tubular torque arm kit is going to help me hook up much better too. I think that'll bring my 60' down significantly. I was expecting 120+ on the trap and now I know why I didnt get it.
