12 Second Club In the 12s yet? Come inside!
2002 A4 202,197miles 12.75
Old 01-30-2017, 09:29 PM
fastsspr's Avatar
Default 2002 A4 202,197miles 12.75
2002 A4 factory stall,jet hot 1 3/4 headers,catback,slp cai with SSRA,3.42,MT tires with Predator handheld the motor have 202,197 miles.
Old 01-31-2017, 11:50 AM
murphinator's Avatar
nice job ! your at high elevation there too which makes it more impressive. My M6 car has 255k and still pulls real strong high miles doesn't seem to affect performance much , its either hurt or its not in this case its not lol
Old 01-31-2017, 02:02 PM
fastsspr's Avatar
Thanks. Yes I'm at close 4000' above sea level and that make it a challenge to run good. Yes you are right this engines run well with high millage.
Old 01-31-2017, 06:15 PM
gesto's Avatar
Good to see you posting some good times! I love these high milers. Can't wait to see what it does with a converter.
Old 02-05-2017, 11:18 PM
fastsspr's Avatar
Thank you. I going to swap to th400 at the same time 4k FTI stall to see how it can do. I spec to do a low 12s.
Old 03-14-2017, 09:41 AM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Well done! Nothing like breaking the hearts of the H/C/I and power adder guys - with stock junk driven well.
Old 03-15-2017, 12:33 AM
spicebird98's Avatar
As others have said great times for the elevation, mileage aside. That would put u in the 12.30's at sea level, right around what I ran with the same bolt ons
Old 03-16-2017, 03:17 PM
FLiP726's Avatar
That's badass! any weight reduction?
Old 04-25-2017, 11:18 AM
Cahill93Z28's Avatar
nice times!
Old 03-19-2018, 06:43 AM
fastsspr's Avatar
Default New best for the camaro
Still have a sealed factory motor ,factory intake. Put a yank 4k went to the track yesterday. Was a 25mph croos wind and 58 deg temp. The car now have 207k miles.
Old 03-19-2018, 06:47 AM
fst100's Avatar
nice PB on your setup! I'm hoping to break into the 12s eventually after I get my stall in. I'm on the 2.73 gears still though as opposed to 3.42 that you're on. did you swap just the gears out or the entire rearend from a donor ss?
Old 03-19-2018, 10:55 AM
fastsspr's Avatar
Hello, my previous time was with the 3.42 already in the car. My car a factory 2.73 and I swap the posi because i had one laying around my garage with 3.42.
in this round I bought a used Yank 4k with a Performabuilt 60e and a 25% ud pulley.
I have lower the tires to 17psi the car feels good but I think is a little is still room to break into the 11s before I go for cam and heads.
Old 03-19-2018, 10:57 AM
fst100's Avatar
cool. what RPM are you shifting at? also if you haven't done any suspension mods yet might be a good idea now such as LCA, remove front sway bar, and phb
Old 03-19-2018, 07:02 PM
fastsspr's Avatar
I **** the car at 5500rpm ,the car have a non adj. LCA only and no front sway bar. I have the rear Vikings doble adjustable for the back waiting to be installed.
Old 03-19-2018, 07:55 PM
fst100's Avatar
why shift at stock shift points?
Old 03-19-2018, 10:19 PM
fastsspr's Avatar
I shift at that point but it go to like 5800rpm. When I shift the car at like 6000rpm the car was slower. Based test that i make the car like to be shifted in that specific spot.
Old 03-20-2018, 08:20 AM
big hammer's Avatar
Ls1’s are very regarded
Old 03-20-2018, 04:16 PM
Kcutty85's Avatar
What are you using to adjust shift points? I didn’t think the predator handheld had that capability.
Old 03-20-2018, 04:21 PM
HCI2000SS's Avatar
I'm surprised your car does better at 5500 vs 5800-6000. Most stock head and cam LS1's I've seen prefer closer to 6000 for max performance
Quick Reply: 2002 A4 202,197miles 12.75
