12 Second Club In the 12s yet? Come inside!
Bolt-on LT on a Mission
Old 04-02-2005, 12:05 AM
roadtrip120's Avatar
Default Bolt-on LT on a Mission
New best tonight
1.70 60'
12.58 1/4mile
109.25 mph
Alt 3600ft
DA 2800ft
Now i am buying a trailer a headed to Houston for some good air and lower DA. Bolt-on M6 record here I come!
Old 04-02-2005, 03:02 PM
95z6spd's Avatar
nice times...are you running stock rocker arms and springs?
Old 04-02-2005, 04:12 PM
No, I upped for the 1.7RR, but i think the springs are gone, I have noticed that she has been falling off hard after 5700rpm. I think I'll buy some new springs and see if that fixes it.
I thought you might notice the new times.
I bought some relocation brackets and some v-6 springs for the front. The three year old nitto's hooked like a champ. 1.70 60'. My K-member should be here next week.
Thanks for the help with the syspension , tips. Sixty foot made all the difference.
What did ya think about the the 12.6 at 109 put down by 96silverram on your post. Not to bad. Looks like we have a little compition.
Old 04-02-2005, 06:41 PM
95z6spd's Avatar
Impressive..I'm glad to see some other REALLY good running LT1 6spds out there. I cant wait to get to the track. I need to order a clutch like yesterday.
Just been real busy lately. I've been driving the GTO lately and it sure is badass. The Z is coming out soon tho, I WANT THAT RECORD.
I've had my shiftlite set at 5800 all of last season. It seems to pull all the way up for me, although I do think I lost some spring pressure on my stockers. I also wish I was the same weight as you, I'm pushing more then 200lbs more than you...Power to weight is the key. I know they kinda did it in GM Hightech magazine, but it would be awesome if they had the top 10 fastest 6spd bolt on lt1's head off in a neutral track. ATCO! I think we'd see some crazy times. I'd go all out if we could make that happen. I'd be determined to go 11's @ 3250lb raceweigt with just bolt ons(including springs and rocker)
Old 04-22-2005, 12:19 AM
96silverram's Avatar
Hey Roadtrip120, what part of Texas are you from ? I'm in Dallas (now). I'm really hoping to go at least high 12.40's or very low 12.50's with decent air. If I can actually get some really good DA (like houston) I'm sure the car would go a number better than I expect. I'm curious how much you think you picked up from doing the 1.7 RR's. I had considered doing the 1.7's to pick up an easy 1 mph and 1 tenth, so I've heard !
95z6sp, your stuff is runnin strong !
Old 04-22-2005, 01:19 AM
1BDWS6's Avatar
A buddy of mine here in Bowling Green ran an 11.99 at 109 this past Sat, in his 94 ta....his is a cam and bolt on car....
Old 04-22-2005, 08:51 AM
95z6spd's Avatar
Thanks Silver ram . I actually think 1.7 RR's and some good springs will net you closer to .2 and 2mph...That would put you out of the hunt for the SI record tho, but you could go for the bolt on record.
Old 04-22-2005, 10:09 AM
TWS
TWS's Avatar
Congrats! My '94 didn't run 12.5's until I had ported (stock) heads and Comp XE 502 cam.
If you don't want to go all the way down to Houston, SAR is a good track. Probably won't have as favorable DA as HRP, but still a good track.
Old 04-23-2005, 01:44 AM
Originally Posted by TWS
Congrats!
Where is SAR?
Update
I just ran again tonight, with 3300ft DA
1.79 60' (Horriable)
12.5 1/4mile
109.76 mph
Same time as two weeks ago but this time higher DA and almost a tenth higher 60'. I haven't figured out the new BMR adjustable torque arm yet.
Thanks for the comp.
Old 04-23-2005, 08:18 AM
95z6spd's Avatar
Go for it man..If you can get some good air....let it rip. I'd love to see a 6spd bolt on LT1 in the 11's
Old 04-23-2005, 11:33 AM
Moderator
BizZzatch350's Avatar
Awesome times man, if you head on down to HRP shoot me a PM and I'll meet you out there. I really like your Z28, looks clean as hell
Old 04-23-2005, 12:00 PM
TWS
TWS's Avatar
Originally Posted by roadtrip120
Where is SAR?
http://www.sanantonioraceway.com/
Old 05-13-2005, 02:45 PM
Mattybz28's Avatar
Hey roadtrip... have you made a pass yet with the nitrous?
Old 05-15-2005, 09:35 AM
ctsls6's Avatar
Hey Roadtrip120 What Bolt Ons Do You Have. I Have A 95z With 1.6 Bbk Stortyies And 3.73 Cai 160 T . It Ran 14.23 At 98 Before Gears. I Have Install A 2500 Conv. What Do You Think It Run 13.5 I Live In Fla.
Old 05-17-2005, 12:43 AM
Mattybz28-- No nitrous times yet, autozone clutch wont hold the hp from a stop..
ctsls6--I have every bolt-on, and then some.(Ls1 lid) . Not sure what you will run, alot comes into play, tires, 60' time, stall, gears, weight, altitude, density altitude.
I hate to quess, and be wrong. Get that mph higher and you will notice a drop in ET.
Good luck , later
Quick Reply: Bolt-on LT on a Mission
