12 Second Club In the 12s yet? Come inside!
disapointed low 12 second run with 408
Old 04-22-2006, 09:15 AM
SSPerformance's Avatar
Default disapointed low 12 second run with 408
Dident have my skinnies on the front had my fat 17x9.5s and i think my 3.73s in the 12 bolt are hurting me pretty bad. im runing a m6 with a 26x10.5x16 et street. Im pretty shure i can get a 119mph and high 11second run how the car sits.....
60 1.704
330 5.071
1/8 7.799
mph 89.82
1000 10.156
1/4 12.108
mph 117.19
Old 04-22-2006, 09:32 AM
97blkz's Avatar
How much power did it make? Suspension work? ET is not awful but can get better. 6 spds are not easy to drag race.
Old 04-22-2006, 10:48 AM
Administrator
unit213's Avatar
I would think your 408 should make around 500rwhp N/A which is good traps
in the 120's. I wouldn't bee too concerned about ET. That's just traction, suspension,
and driving issues. The lack of power is interesting.
Old 04-22-2006, 10:54 AM
Flash99's Avatar
Get that 60 ft down a little bit and you should be in the 11's without any problems. It takes alot of work to launch an M6 right.
Old 04-22-2006, 11:56 AM
it made 490rwhp and 480rwtq.... im still geting use launching the car.....how bad is the 3.73 gear hurting me
Old 04-23-2006, 06:02 PM
anyone else on this
Old 04-24-2006, 07:56 PM
408 z28's Avatar
4.10 ftw
Old 04-24-2006, 08:05 PM
yea im gona order up a set of 4.10s and a spool....not shure to do qa1s firts in the front or the gera i wana get down in the 1.5 60 foot time but probly gona need both
Old 04-30-2006, 05:47 PM
1BAD_Z28's Avatar
i would def take the car to a different dyno, something doesnt add up. my car with mac mids/lid/free mods/stock weight went 12.6x @ 114 on a 2.0 60' . You have 490rwhp and only trapped 117?? as far as the 3.73's go their fine id get your motor checked out first
Old 04-30-2006, 05:56 PM
97blkz's Avatar
wow 490 , umm are you short shifting the crap outta it?
Old 04-30-2006, 06:35 PM
i figured out the problerm i had hydo issues with the master......fixed it readyt o go again
Old 05-01-2006, 08:03 PM
30th t/a's Avatar
make sure you got a shift light. if you dont, get 1 asap. i went from trapping 113 to 117 just by being able to shift exactly were i needed to be. going by ear doesnt work for everybody.
Old 05-01-2006, 08:20 PM
sleeperstyle's Avatar
so the clutch was slipping? or you couldn't shift fast?
good luck, post up the results.
Old 05-01-2006, 09:03 PM
i couldent shift at my max because the clutch wasent disengaging all the way
Old 05-03-2006, 03:38 AM
bigbadblackws6's Avatar
when are you running next to post new times? where in florida are you at?
steve
Old 05-03-2006, 05:53 PM
steve
going to the track friday.....im in NY the town is florida just like it says
Old 05-03-2006, 10:28 PM
91Z28's Avatar
Excuses...........
