12 Second Club In the 12s yet? Come inside!
How did you get your LT1 into the 12's?
Old 08-23-2006, 03:00 PM
Michigan Skip's Avatar
Default How did you get your LT1 into the 12's?
What mods did you do? What converter/ gear combo?
Old 08-23-2006, 06:35 PM
QWIKWS6's Avatar
LT's, 2800-3200 stall, DR's, CAI and you should be there...
Old 08-23-2006, 08:12 PM
You sure? I have a 3200 , ET Streets, K&N CAI and only run 14.00's That's with a 2.73 rear gear which should only net me abut 2-3 tenths if I swap it out to a 3.42 or 3.73. LT's would net me over a second?
Old 08-24-2006, 01:56 AM
00Vette's Avatar
Originally Posted by Michigan Skip
How to get your LT1 into the 12's?
Remove the LT1 and replace with LS1!
J/K..........ask 2fast4lv! He has ran consistant mid 11's on his LT1 (n/a) and just went 10.32 with some nitrous. I'd send him a PM or something. He works on all our cars around here. Great mechanic and very knowledgable.
He is a good guy and will be very helpful. He knows his ****!
Old 08-24-2006, 02:08 AM
94z28L's Avatar
with what i have im runnin mid 13's with 5800 ft of altitude and a density altitude of over 7500ft at the last session
Old 08-24-2006, 02:10 AM
daniel6718's Avatar
stall gears tires...exhaust wont hurt
Old 08-24-2006, 03:52 PM
Ellis?
Old 09-06-2006, 05:54 PM
fastfbody's Avatar
Default ...
i did it with a super charger,lts,duel force clutch,drs and 42lbs injecters (only 6lbs of boost)im in no hurry to blow my car up.
Old 09-06-2006, 06:14 PM
the_merv's Avatar
Just a little tweaking..
Old 09-06-2006, 07:19 PM
carzman5678's Avatar
Stock was 14.0 for me.
Several upgrades but no time for the track. With TD's, Stall, Intake, DR's, Tune. I went a 12.8. Add a 120 shot and I went 12.2
Old 09-08-2006, 01:10 AM
urbanhunter44's Avatar
dumped LTs, CAI, slicks, lcas. time in sig.
Old 09-08-2006, 01:32 AM
hashtagBMW
Speed Density's Avatar
Push it.
Get rid of your LT1 they suck, just a SBC with reverse cooling. Its garbage.
Old 09-09-2006, 09:26 AM
the_merv's Avatar
This little 350 SBC with reverse cooling is killing the LS1's around here. And it's got no problems hanging with the LS6 Corvettes...
Old 09-09-2006, 12:22 PM
sdm1234's Avatar
With my mods, I'm running 13.8. With DR's I'll be running 12's???
Old 09-09-2006, 06:25 PM
the_merv's Avatar
You might be able to knock off about .2, Drag Radials won't take off enough to put you in the 12's.
Old 09-09-2006, 06:56 PM
raymond mckinney's Avatar
Drag radials, gear, Lt's,and a tune is all u need!!
Old 09-10-2006, 12:08 AM
donkey mule's Avatar
Most of the mods you have listed are not the kind that are going to net some improvements in ET's, with exception of the exhaust work. A 13.8 still seems slow with the mods you have. A set of good DR's , 4.10's , good weather and the driver mod and you would probably see 12's!
Old 09-10-2006, 03:22 PM
sdm1234's Avatar
I'm also running on Falken 451's with nearly 40 lbs of air, so that could be why I'm slow, too... I even get extremely squirelly going into 2nd gear.
Old 09-17-2006, 10:05 AM
JimboManJones's Avatar
Ouch man, something must be up with your car for it to be running that slow, have you ever weighed your car? You should be at least mid-low 13, maybe you just need practice?
Old 09-17-2006, 04:38 PM
14.40's stock, then 14.00's with a K&N and 3200 converter. Now after adding 4.10's it runs 13.90's. What else to do? LT's gonna drop another whole second?
Quick Reply: How did you get your LT1 into the 12's?
