if i could only launch... 12.92@ 115mph
Made it out to the track for the First time since i bought the car about three months ago. I was happy to get a 12 on my first time to the track but i know there is much more in it, i ran a 13.0 on the first pass, 13.5 on the second when i missed third, 13.2 on the third bogging really bad off the line and on the fourth pass i ran the 12.92 @115mph. My 60ft times were terrible on every pass, quickest i had was 2.39, . The 275 street tires just wouldnt grab. I have a set of prostars with ET streets that ill put on next weekend, should be interesting to see how much they help. I left them off this time just to see what i could run in full street trim and a half tank of regular 93 octane.
Car is a 98 z28 with stage 2.5 5.3 heads milled, mild cam, long tube headers and ls6 intake.
Anyone care to guess what time i would run with a 1.8-1.9 sixty??
You really do need to work on those 60' times but that will come with practice.At least you know that is something that can be fixed. The mph is a little low for a h/c setup but there are so many other variables that would affect that. Weather conditions, track elevation, shift points, etc. Good luck though, I'm sure your times will improve drastically with better tires and more time behind the wheel.
From what i hear get you some nitto 555 they are pretty cheap and will get you out of the hole. I think for 17'' its 159.00 and cheaper the smaller rim you go...those prices are from www.discounttire.com
