12 Second Club In the 12s yet? Come inside!
What parts are needed for low twelves?
Old 05-08-2008, 08:53 PM
sleepersti's Avatar
Default What parts are needed for low twelves?
I have a 2000 camaro SS and want to know what I need to run low twelves.
Old 05-08-2008, 09:19 PM
GG01SS's Avatar
Depends Auto or M6? M6 = Full bolt-ons w/ 4.10's, full weight car may need cam too.
Old 05-08-2008, 10:04 PM
sleepersti's Avatar
M6, full weight, When you say full bolt on's. what does that all include?
Old 05-09-2008, 06:55 AM
PowershifterNC's Avatar
basic bolt ons...intake exhaust tb mass air and get a tune...no cam or suspension mods needed...just mickey thompsons and a lil luck with the stock rearend
Old 05-09-2008, 07:18 AM
ls1mongrel's Avatar
150hp shot and some tire, I have a buddy with stock t/a, a4 no stall 150 shot runs 11.50 !
Old 05-09-2008, 01:44 PM
sleepersti's Avatar
I plan on -Long tubes, TB, Intake, 4:11's, Cam, ET streets, Tune.
Good for low twelves right?
Old 05-09-2008, 05:02 PM
ta_06374's Avatar
That should do it....
Old 05-11-2008, 04:21 PM
s346k's Avatar
i'd hope a cam would put him mid-high 11s in an m6.
the driver mod is the best thing for a low 12 sec pass in an m6 car. can easily be done with bolt-ons and a drag radial.
Old 05-12-2008, 08:04 AM
my thoughts exactly
Old 05-12-2008, 11:46 AM
GG01SS's Avatar
Stock clutch and stock rear = weak link. My stock clutch started slipping w/ Drag Radials at 12,000 miles. Holds better on the street, currently have only 22,000 miles, looking to upgrade to LS7 clutch and Flywheel, then I hope the rear holds w/ low 12 second pass before Headers, but may need 4.10's.
Old 05-12-2008, 12:23 PM
SSdreamz's Avatar
my brother runs 12.2 with a 1.9 60ft. he has long tubes(pacesetter) torquer 2 cam and gears 4.10s and some ET Streets....
once he gets the tire pressure and launch rpm down..easy high 11 car
Old 05-14-2008, 02:53 PM
Dragkid1917's Avatar
Technically full boltons would add an Underdrive pulley and an electric water pump. Id do a UD pulley as ive herd its worth a tenth, mines sitting at home redy to be installed. You can also do little things like run with very little gas, 93 or 100 octane UNLEADED. Each gallon is 7 LBS and 100 lbs is ROUGHLY a tenth. You could take out spare tire/jack (37lbs). Full boltons minus EWP should get you deep into the 12's thoo.
Old 05-14-2008, 08:45 PM
Blackhawk777's Avatar
I can probably squeak a 12.5 with my mods. I'm short a cam and a real rear end.
Old 06-07-2008, 04:58 PM
01ssreda4's Avatar
surely....
Quick Reply: What parts are needed for low twelves?
