Advanced Engineering Tech For the more hardcore LS1TECH residents
Window switch, and e cut outs.
Old 07-06-2009, 09:53 AM
RsSean's Avatar
Default Window switch, and e cut outs.
I have a idea that I am going to try to use a DMH cutout and a MSD digital window switch. My idea that I have is some what similar to a nitrous window, but with a cut out. Have a arming switch to turn on the window swithch to open when you want to race, or here some rubble or to arm the system. Have the window set somewhere around 2600-2800 so it would open fully around 3-3500 rpms the power band of most cars. I know I can get to system to give the cut out power to open, but how can I get the cut out to shut off when it is full open. (relays) Then if the rpms drop below the window to have the cut out close and then shut off, so the motor does not burn up. I think it will be interesting to have something set up like this.
If you have any inputs that would help me in my idea or hints please help me out.
Thanks
-Sean-
Old 07-06-2009, 10:09 AM
Jordan S.'s Avatar
haha That would be pretty crafty. I'm not sure what those motors are like on the cut outs though.
Old 07-06-2009, 08:07 PM
Moderator
jimmyblue's Avatar
Problem is, the motors are too damn slow, by the time you
get it open the window is over.
Now, a plain TPS switch setup might not be so bad. You need
a couple of relays and some sort of one-shot to get a close-
back-up duration that gets it done, but doesn't keep the motor
lit up all the time.
Thought about drawing this up before but never got around to
it.
If you had good controls you could probably take out the
limiting resistor that many of them put in, and get faster
actuation. But better safe than sorry, unless you have
a spare motor.
Old 07-06-2009, 09:50 PM
RsSean's Avatar
Yeah I understand that they are slow. Mine takes 3 second from full close to full open. I am going to find out how the C6 Z06 works with the bypass in the motor.
Now I am not going to be taking out the resistor int he cut out, I am sure you can get it to open faster. I am going to do it safely and contact DMH and see what they say to open the cutout faster and see what the manufactor says on that topic.
It is going to be a work in progress and see what I can come up with.
Old 07-06-2009, 11:13 PM
Awake455's Avatar
IIRC the C6 Z06 uses vacuum operated actuators to slap them puppies open or closed really quick-like.
Too bad there isn't a way to configure something to give power to a circuit for only a limited amout of time...or is there?
Old 07-07-2009, 07:36 AM
RsSean's Avatar
Won't be using that then. Not going to swap the entire system that I have now.
Old 07-10-2009, 03:42 PM
spy2520's Avatar
What about if you tried to modify an throttle-by-wire systen to open the exhaust? That would be cool. They seen to have the speed.
Old 07-13-2009, 09:55 AM
RsSean's Avatar
Well that is a idea but I would have a cable that would be running from the front all the way to the back right corner of teh car. Just to long.
Recently I got the cut out to open adn click of when fully open. I am now working trying to get it closed.
Quick Reply: Window switch, and e cut outs.
