Cam bearing install post? - LS1TECH
Advanced Engineering Tech For the more hardcore LS1TECH residents
Thread Tools Search this Thread
Old 02-03-2011, 12:04 AM   #1
hdkarmy's Avatar
Default Cam bearing install post?
I have an lq9 I'm putting together and the cam bearings are showing copper on the bottom and one side. the rod and main bearings look great. the motor is very clean inside. my machine shop wants me to disassemble the entire motor to change them. has anyone done a post on removing and installing them? the motor is on a stand, the heads are off getting a valve job and i have the pan off, just finished putting in the rod bolts. can I change them with out tearing down the motor?
hdkarmy is offline   Reply With Quote
Old 02-03-2011, 11:13 AM   #2
fergymoto's Avatar
You can, but tearing it down would be the right way.
fergymoto is offline   Reply With Quote
Old 02-03-2011, 05:37 PM   #3
hdkarmy's Avatar
Unhappy
were do i get a cam bearing remover/installer? I will pull the crank I just don't want to pull the pistons. I would be afraid I would damage the rings.
Old 02-03-2011, 09:37 PM   #4
Ethan[ws6]'s Avatar
Wrong section for this, but I've heard of people actually changing them out in car. I have no experience with it, but I know you shouldn't have to take the bottom end apart to do it. They probably just want you to disassemble it because it will be easier for them to move it and work with it.
Ethan[ws6] is offline   Reply With Quote
Old 02-04-2011, 06:31 PM   #5
You have to have a way of checking that the oil hole in the bearing is lined up. if you can find a way to do that with it together you can do it in car, i would think you would have to take the oil pan off.
mwg2600 is offline   Reply With Quote
Old 02-05-2011, 05:44 PM   #6
hdkarmy's Avatar
thanks guys
Related Topics
Thread Thread Starter Forum Replies Last Post
My rotating assembly is hard to turn once the rods are torqued down. Suggestions? 2000SS1979 Generation III Internal Engine 9 05-27-2014 09:26 PM
Scat Rods Quick Ranger Generation III Internal Engine 5 12-07-2013 10:17 PM
What to do to '05 LQ4 bottom end? LS2Monte Generation III Internal Engine 2 10-15-2010 09:56 AM
bent push rod ? brand new bad lifters ? HELP ! TurboZ28408 Generation III Internal Engine 7 03-27-2010 05:41 AM
Cam will not fit past new cam bearing in new shortblock, need tech help.. FEAR THE LS1 Generation III Internal Engine 9 04-11-2003 08:19 AM
Tags
bearing, bearings, cam, disassembling, install, installation, installiation, installing, ls1, pontiac, replace, tech, ws6, youtube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
