Advanced Engineering Tech For the more hardcore LS1TECH residents
D585 Coil Specs
Old 05-18-2011, 06:48 AM
danlee's Avatar
Default D585 Coil Specs
I'm putting D585 coils on a Ford motor. I need to know what the igniter input signal needs to be. I will build a suitable interface box to drive the D585 coils.
Is the Interface simple 5 Volt logic?
Does it need an open collector to pull a 12 Volt input low?
Is the dwell time a Logic '0', or a Logic '1'?
What source or sink current is required?
Quick Reply: D585 Coil Specs
